#1 | |
https://www.hondagrom.net/forums/49-...ds-better.html This works only on the 1st gen Grom forks. For the second gen Grom forks... https://www.hondagrom.net/forums/7-g...orks-free.html In the two links, you can see how they're different. I have no idea how the Grom Clone forks are (I never opened mine up). Either way... I think swapping to the Grom forks like you did is the best option since it opens you up to the aftermarket fork internals. |
#2 | |
Vader 125 10 front suspenders
My Vader/10 front suspension is similar to the Gen2 Groms. Here a couple pix of the innards. |
wlfpck Thanks for that write up, I was aware that it did consist of some hardware items but did not have a list to go by. Next yr when I get around to improving the forks I might try this along with new fork oil and the race Tech springs. Thanks again.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
#4 | |
This is the part list that is for the 1st gen Grom to do that ND4sph mod. 2x - 59363-F - 1in Spacer (5/16ID - .469in OD - 1in Long) 4x - 3815-F - Neoprene washer (7/16ID - 1in OD) 2x - 43110-N - M8x50 1.25 pitch bolt 2x - 43893-E - Small M8 Washer The part numbers are from Hillman. |
These are the Preload adjusters I used on my Gen 2 Vader
they are from SSR , pretty sure they were about $99 . Together with a fork oil change to 15w they made them pretty decent .These are adjustable as far as preload, you can get a set of Takagawa preload adjusters for like 49$ from WeBike but they are a set " max" preload and are not adjustable .
#6 | |
I do have a pair of these laying around somewhere, I will probably go this route with the fork oil and springs, still looking for a 2015-2016 Grom upper/lower triple tree assy for cheap.
