It's still a 9% increase in displacement which on a head flow restricted motor like the CG may not add any hp, but it will pump up the torque.
On the BB kits for the KTM rfs motors, some of the guys complain they lost a little rpm over rev, but after you adjust your riding style it's a win. Of course we used to have a bunch of cams we could use to make up for the overrev if we wanted. The cg cams are a little more limited in selection. I cant wait to see how it works.
#2 | |
Yeah the "right" way to do it, is machining the case. To be honest, is not worth doing it. A modded Hawk like the way dan is, can already beat a stock "300"
The picture above is the "GATO CG300" it has the same top speed than a 230 but it's more torquey About the cams you would be surprised about all the differents profiles they made for the CG. To be point of being ridiculous |
I ordered one of the kits but wont make any efforts to install it until this summer when it's too hot to ride here.
For now I'm messing with suspension.
There are quite a lot of cam profiles out there for these motors. The main reason I went with the current WGK cam profile that I do have is because it required no other engine work since it adds no lift. The second you increase lift and duration on the CG engine design the first limitation you run into is the valves try to become best friends with one another during overlap. The simple solution is to machine back the valve seats so the valves sit deeper into the head.
As I have tried to explain to other guys obsessed with trying to do the same work. If their goal is more horspower, a cam is a better option than a bigger cylinder. I also wouldn't bother with a larger bore without having some head porting done at the very least.
Let's face it, we'll never make high rpm firebreathers out of these, but we can make some torquey trail bikes out of them.
My experience with riding on the trails isn't that the bike doesn't have enough power as much as I need practice and better suspension.
#6 | |
Those "Gatos CG300" can reach around 162 km/h (100 mph) at 10.000 rpm Which is quite impressive for a CG From my point of view, keeping the engine 230cc and modding the rest is the best balance between performance and durabilit. |
#7 | |
Since installing this on my bike I have had zero issues. With summer coming on I just installed an oil cooler which really reduced engine temps. I'm still really in the break in stages as Im only about 250 miles in. I really like how on road capable the bike is now. No more slowing down traffic on the hills. Looking forward to seeing Dan get his built. I know it'll be top notch!
#9 | |
I have a few questions for you, Megadan. In post # 14, you discuss your chain tensioner. I'm considering installing these on my twin TT250's.
Do you like the one you purchased? Has it held up well? What maintenance is involved with it? What improvements have you noticed with it? Was it worth the expense? Would you choose a different model if you bought another one? Thank you for your valuable insights. :-)
___________________________________ 2021 CSC TT250 - Silver (Mine) "Buzz" 2021 CSC TT250 - White (Wife's) "Seymour" 2021 CSC TT250 - White (Daughter's) "Gemini" |
#11 | |
#12 | |
If I flip the sprocket, then the cover definitely needs to be clearanced. It would keep the chain off of the engine case though. Who knows, I might just go through with it, but not tonight. I just got done cleaning and adjusting my chain lol. No energy left for modifications. I was hoping my Nibbi carb would have arrived by now so I could have installed it, but alas... nothing.
#13 | |
