08-19-2018, 10:11 AM | #1 |
Twisted off head CDI case
Read the Hawk valve thread and got worried so went to check my valves first thing this morning. The head to this bolt snapped off and left the rest stuck and floating around in the hole. I tried pulling every bolt to the entire case to see if I could get the bolt out from the inside but it won’t budge. I’m assuming running the motor w/o that top seal will ruin it so it’s a downed bike ugh.
08-19-2018, 10:45 AM | #2 |
I got the case off/on. Just need a new bolt now I think.
08-19-2018, 12:43 PM | #3 |
Trying a 1.5 inch oil plug from Oreilly
Cross fingers |
08-19-2018, 01:18 PM | #4 |
Good luck. Hopefully it works out
08-19-2018, 02:24 PM | #6 |
I pulled the entire case and the damaged bolt came out on its own. Looks like I went too far and the plug cap wasn’t tough enough to stop and just shattered. The 1.5 inch parts store oil plug fits. The shortest one I could find is too long I believe so I added a metal washer, the nylon washer it came with and an extra O ring along with the original. I cranked it down to what felt appropriate, replaced the 1.5 quart of oil lost and put about 5 miles on it.
Wow! All that mess and trouble just checking valve clearance. I’ll check the Honda place out see if they can find a proper one or does anyone know the part number to order one off amazon or wherever? Motorcycle! Last edited by ChipToothy; 08-19-2018 at 02:26 PM. Reason: “The Struggle” |
