05-05-2018, 11:25 PM | #1 |
Rhino’s be here
Got my two Rhino’s in from Txpowersports Friday.
Started putting them together, no surprises so far. The build date on them is 12/17. The only change seems to be that the bulky tail lamp is now a smaller led unit. Tag says 197cc, haven’t checked that on the engine yet. |
05-06-2018, 02:22 PM | #2 |
Well I found the swing arm wasn’t tight. Trivial matter.
05-07-2018, 04:49 PM | #4 |
Yep, second that from Paul, and Loctite blue on everything. Although they seem to be applying something like Locite tape now on the bolts already installed in crate. I got mine in Nov., and they had it applied. So we just put the blue on everything needed for assembly.
Another thing I recommend close inspection on, is the rear brake switch. Look real closely at that puppy for cracks in the plastic housing! Apparently they can break easily, probably during shipping and/or assembly. If it even halfway breaks, you can be blowing fuses and wondering what's going on. Gorilla tape will do in a pinch. Just wrap it up to hold til you get another one if needed. |
05-08-2018, 08:40 PM | #5 |
Mine came with a large number of nylock style nuts. I was rather surprised. I also got a machined aluminum gas cap. The headlights are led (haven’t check how well they work) as is what seems to be a new led tail light. What I found wrong out of the crate is the front seat “u” clip is cracked and I will have to create/reinforce a replacement.
The carburetor has a float issue, started leaking fuel out of the overflow after the second ride. The unit either has a sticky float or it’s not set right as it idles a tad wonky. Pretty happy with it so far, going to start putting the second Rhino together this weekend. Like Paul I bought two of them! |
08-13-2018, 08:29 AM | #7 |
Just remember.....Once you get it, relax, get coffee, put the kids in a shed somewhere, the ex in a cement filled barrel, and get a few wrench's and double check the tightness on EVERY bolt including frame ones that are commonly missed.
or not, but please do the ex n cement barrel for me, lol |
08-13-2018, 10:49 AM | #8 |
Lol sooooo true!!!
