05-10-2018, 05:13 PM | #1 |
Please help Apollo 250cc wire issue
Hey guys I need help!! I just got my 250 put everything together and realized some how the 2 green wires that run into the clutch broke out and realized the little black holder is shot. I attached 2 picks I hope someone can help me bypass this because the bike won't start, it 100,% the issue
05-10-2018, 05:17 PM | #2 |
Does it crank? Should be able to start in neutral. If the starter is turning and not starting check to make sure the kill switch is off. That's just a safety switch so it won't start in gear without the clutch pulled.
05-10-2018, 05:30 PM | #4 |
They complete the starting circuit when you pull the clutch if the bikes in gear. They won't keep it from firing. Pull the spark plug and make sure it is firing. Also check to make sure fuel is reaching the carburetor by opening the drain screw on the bowl. Did you try chocking the carb?
05-10-2018, 05:37 PM | #5 |
You can just tape them up until you get another switch from the dealer. Don't connect them together because it will start in gear.
05-15-2018, 10:56 AM | #6 |
I'm getting spark, the bike actually did start one time, it ran for a minute but wouldn't idle and cut off. Where is this screw your talking about?
05-15-2018, 10:57 AM | #7 |
Yes I've also tried with the choke in all 3 positions
