04-08-2018, 01:42 PM | #1 |
Engine noise
IT does this rattling noise once it is warmed up and at a certain rpm anyone know what it is? Valves are adjusted
Heres a video |
04-09-2018, 06:34 PM | #2 |
Does noone know? I don't mind fixing it just would like ideas on what it could be.
04-09-2018, 06:42 PM | #3 |
Lousy speaker on my tablet so hard to tell. You say valves are adjusted but are you sure it was done right?
04-09-2018, 06:47 PM | #4 |
Yes I followed the guide posted on here done it 10 different times to make sure it was right.
04-09-2018, 10:48 PM | #5 |
noise
check oil for metal.... was it ever changed to the 10-40 oil ??? that is a good start ..
04-10-2018, 07:18 AM | #7 |
I changed the oil twice since I bought it i used 15w40 i haven't seen any metal in the oil
04-10-2018, 08:00 AM | #8 |
It sounds normal to me. All I heard is the normal taping of the valves.
04-10-2018, 08:54 AM | #9 |
So there that loud in these motors? I have never heard valves as loud as the sound i hear from it i work on motors all the time but not air cooled pushrod engines.
04-10-2018, 09:11 AM | #10 |
Yes they will be a little noisy. What do you have them set at. I have mine set at .002" intake and .003" exhaust.
04-10-2018, 09:41 AM | #11 |
There Both at 003
04-10-2018, 10:01 AM | #12 |
You will be good at that. When you stop hearing the tapping you will know it's time to adjust valves.
04-10-2018, 10:08 AM | #13 |
Is there a place to buy crankshafts for these engines in the event that something does go wrong it seems to be the only part I cant find?
04-10-2018, 10:12 AM | #14 | |
Just have to check measurements to make sure you are getting the right parts.
04-10-2018, 10:15 AM | #15 | |
