Old 09-26-2016, 01:10 AM   #16
dhanb   dhanb is offline
Originally Posted by david3921 View Post
I must be missing something but how can the ball joints be welded on? The arms and the welds are orange and the ball joint is bare metal. They should be all the same color if they were welded on right? Try taking off the rubber boot and see if there is snap ring under it. Either way you should be able to then either press or beat the joint out.
http://www.schrems.org/product_info....ducts_id=37978 from A quick google image search for A arm ball joint
You can see the welds which have been painted over orange around the joint. You're seeing bare metal because the bottom has been scratched up on gravel and whatnot.
Old 04-30-2017, 10:41 AM   #17
htrrider   htrrider is offline
Throttle Cable
I'm in need of a new throttle cable for this quad any thoughts?
