#16 |
I'll chime in. I am running the PZ30 with stock exhaust and an aftermarket cone air filter. I am at sea level and current set is #40 pilot jet, #105 main jet, needle clip in the center slot, and 2 and 1/8 turns out on the mixture screw. I think I may still be slightly lean on decel so I may move the needle clip down one slot, or try the next pilot size. I think I have a #42 in the set I got off ebay.
#17 |
Here is my plug, unknown jets (no marks), 2 turns out from "seated" on the mix screw.
Help please
12/2016 Rhino 250 |
#19 |
Choke is off, new filter.
The needle clip was in position #2 from the bottom, I have moved it to position #4 counting from bottom up. Seems to have helped the mid range a bit. Retainer clip is present and in position. Here is an updated plug with 3.5 hours of use with the new settings.
12/2016 Rhino 250 Last edited by beyondhonesty; 04-22-2017 at 08:38 PM. |
#20 |
Any ideas?
12/2016 Rhino 250 |
