Loncin RE250 6 speed
I found a good replacement engine for our China bikes. Loncin RE250 6 Speed Not bad for around $530. 6 speed and counter balance
Wonder if they will bolt right up without any modifications? That is a great price considering the extra gear and being counterbalanced.
2016 Bashan Brozz 250 |
It's OHC too!
I think this is the motor that Fastdoc once put in an XR200. Not sure if it was a six speed though.
#4 | |
Specifications
Engine type
Single cylinder, 4 stroke, oil-cooled Displacement 223.0cc Bore x stroke 65.5×66.2mm Compression ratio 9.2:1 Maximum power 17.7hp(13.2kw)/8500rpm Maximum torque 17.2N.m/6000rpm Starting method Electric Ignition system C.D.I Idle speed 1300 rpm Engine oil capacity 1.3 L Transmission Transmission system 6-speed Final transmission Chain
This is one of the Enduro bike's it come on.
Might be the next mod for the Bashan WILL 200... 6 speeds, OHC engine, and 223cc's sounds great to me
![]() I also found a few sweet oil coolers on that yoycart website... just don't know what one to pick... I can't read the "Description" page and all the translator websites claim it's already translated into English ![]() Here's one of them http://www.yoycart.com/Product/548221350096/ Can anyone make out what one comes with the nice "rock blocking plate"?!? Is it the ones labeled "Mesh" ?!? ![]() ![]()
#8 | |
#9 | |
https://world.taobao.com/item/254075...?fromSite=main
A KLX engine would do nicely, too!
Nuff said. olds_cool63 ======= Johnny Pag Pagsta (replaced 50cc engine with 110cc, modded-out) 2007 Tank Vision Topline Khaos (cosmetic mods, cherry-bombs) 2005 Kymco Vitality 50 2T (70cc big bore kit, other race mods...tops out at 67mph) 2008 Hyosung GT250 (cosmetic mods) 2001 Suzuki Bandit GFS1200S (cosmetic and slight mods...150mph+) |
#12 | |
Regarding confiscation so if it is not going on a street bike why would it be confiscated? Just trying to understand.
2016 Brozz |
That is the only reason I have not bought one yet. I much rather have the stack plate cooler.
#14 |
Every gasoline engine is supposed to be EPA certified. As far as whole bikes go, they are either on-road or off-road, and my guess is, the same is true of replacement engines. This engine, and I am assuming it is not EPA certified, is not supposed to be shipped here. It might make it through, but if enough people order them, eventually they run the risk of confiscation. They are shipped directly from China, so there is no risk for the seller, only the buyer. My post is just an fyi and individual circumstances probably will vary (i.e. some making it through)
#15 | |
