Old 03-14-2017, 10:52 AM   #1
Crazysteve50   Crazysteve50 is offline
Exclamation Apollo 250RX - New Mikuni Carb help!
Just got my carb in yesterday... and my bike will not start... and the fuel keeps overflowing out of the drain... What should i set the mixture screw too? any help with this would be great thanks.
Old 03-14-2017, 11:18 AM   #2
Bruce's   Bruce's is offline
A general setting is 1.5 turns out from lightly seated for the mixture screw .It sounds like your float is stuck though ,you can try lightly tapping on the side of the carb with a hammer to free it up ,or you might have to remove the float bowl and get things moving correctly inside .
Old 03-14-2017, 11:55 AM   #3
Merlin   Merlin is offline
Exclamation
A lot of times when there is no gas in the carb the float will get stuck and tapping it will un-stick it. If that dosent work you need to remove the carb and take it apart to check the float.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
