Old 03-02-2017, 07:01 PM   #16
JMM   JMM is offline
Originally Posted by jeffrey View Post
Left side between fork and brake rotor.
So on the "inside" of the fork? Ok, I was thinking: washer | wheel, spd sensor |
With the " | " being the forks.
Old 03-02-2017, 07:02 PM   #17
JMM   JMM is offline
Originally Posted by timcosby View Post
also those forks go all the way down till the top is flush with the trees.
Yeah they came in all jacked up. I moved them down. Thanks for your help
Old 03-02-2017, 07:04 PM   #18
JMM   JMM is offline
How's the fork oil that comes with it? Did you change it out? Should it be fine, or docypu recommend changing it out while I have it still somewhat apart?
Old 03-02-2017, 07:05 PM   #19
fork spacer rotor wheel speed sending unit fork
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 03-02-2017, 07:07 PM   #20
probably easier than doing it later but mine has a bout 1000 miles on it and they are not bothering me.
2016 hawk
kaw h1 400 tripple
Old 03-02-2017, 07:56 PM   #21
joeboyk   joeboyk is offline
joeboyk's Avatar
use caution changing back brake fluid,did mine ,used a nuematic bleeder and wasnt the same till i took the entire brake system off and bled it on the bench.maybe im an idiot but one the best mechanics i know said it was a poor set up,just my 2 cents.
Old 03-02-2017, 08:00 PM   #22
not having any problems out of my brake fluid why fix if it aint broke
2016 hawk
kaw h1 400 tripple
Old 03-02-2017, 08:35 PM   #23
joeboyk's Avatar
i just wanted to get rid of all fluids put in at the factory ,wish id of left it alone
Old 03-02-2017, 09:53 PM   #24
JMM   JMM is offline
I was thinking the same thing. But I'll leave the brake fluid for now. I think I'll leave the fork oil as well. I was going to do it while I have it semi-apart , but I don't plan on doing any hard core riding. And hopefully, mostly, on-road/pavement.
Old 03-02-2017, 09:56 PM   #25
JMM   JMM is offline
And if anyone wants to do the airbox mod, I had my dremel out and ready. But just ended up using a razor blade. I planed on cutting out as much as I could with the razor, and using the dremel to get nice and close to the edges. But the razor blade worked perfectly, I didn't need the dremel.
Old 03-02-2017, 10:20 PM   #26
hertz9753's Avatar
I used a box cutter and when I down to a certain point the flaps just twisted off.
Old 03-02-2017, 10:34 PM   #27
oldscooter   oldscooter is offline
I'm slowly building my Hawk now. I changed the fork oil since this is the easiest time to ever do it. It didn't look too bad. At first, the left fork had less oil than the right. Let it drain overnight and they both came out the same. 200ml. I changed the brake fluid also. Couldn't tell any difference. The manual called for dot 3, the brake cover said dot 4. The oil is draining out overnight now. At least I'll know exactly what is in the various fluid systems from the start. It's a great project so far. This is a good group to compare and learn from.
Old 03-02-2017, 10:53 PM   #28
engine oil is just a little over a quart. i know the manual says 1.6 but its too much. use the sight glass on the side.
2016 hawk
kaw h1 400 tripple
Old 03-04-2017, 12:53 PM   #29
JMM   JMM is offline
Changed out the factory oil. Zero start ups
Old 03-04-2017, 01:09 PM   #30
hertz9753's Avatar
Honey have you seen my favorite bowl? We also need more rock salt in the water softener...
That oil is nasty looking. Maybe they don't recycle in China, they just send the oil out of the country in motorcycles.
