Another New Hawk has arrived
Came in today. Ordered it late Wednesday night (like 10pm EST). Shipped Thursday. And came in today. Got a black one. Will be on here for help and ideas like everyone else. Got it unpacked, and on the motorcycle jack. Battery is filled and on the charger. Made a list of everything I want/need to change out before I start to ride it.
And was tinkering around, and did the air box mod. Don't know how much of a difference it will make. Anyone else's intake tube come sort of "compressed" in the middle of the tube? Definitely going to be restrictive. Has anyone change out the tube from the carb to the box? Thanks ![]() ![]() ![]() |
Air box mods are worth a try. Easily undone if it doesn't go well.
That's what I figured. And seeing how bad the intake tube is malformed, infigured the more air the better
I did that exact mod to my air box. No regrets. Keep the pics coming
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
That is how the boot is shaped. I have pictures of pretty much everything.
Congrats on the New Hawk, where are you located? Who did you buy it from? Thats pretty FAST shipping. And yes thanks for the pics, keep em coming.
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300 |
#7 | |
Ordered it from "LowestPriceATVs.com", which is Ricky Motorsports. I'm located in Massachusetts, in the southeast part of the state, on the water. But I live on a dead end street. And if I open my gate in my backyard, it opens to miles and miles of woods and trails. So I don't have to travel far to ride, luckily! |
#8 | |
#9 | |
So, put the new Ngk plug in, from tire and brakes on, battery has been filled and charged. Got the quick connect battery tender I tossed on there as well. The little charging connecting just pops its little head out under the seat for a quick trickle charge while she sits, Not being used. While doing this I noticed one of the forks is about 1" higher than the other. So I'll have to fix that before I finish. Everyone says to change the oil. I went and bought some new oil. Is it fine to start it up and warm it up with the oil it comes with? Or just ditch it right away? |
I would ditch the engine oil right away before you even start it... although some see "no harm" if the engine is running a few minutes to heat up while "under NO load" (not being ridden... just idle)...
It's what, $5 max for a quart of good name brand oil... the cheapest engine I can find to replace the stock one is almost $450 after shipping charges and it's not a "direct fit" (swap wires and regulator/rectifiers/cdi/etc.)... I myself don't think the Chinese Engine Oil that came with the bike is worth a $445 gamble
#11 | |
And I've read the brake fluid should be changed out. Anyone else read and/or do this? It's super easy and I have a ton a brake fluid. Just didn't know if I'm wasting my time doing it...
The front should be like every other motorcycle I have seen and worked on, usually looks something like
Spacer / Wheel / Speedometer pickup I don't own a HAWK so I'm no help as to what it should actually look like DOT 4 brake fluid will be your friend ![]()
#14 |
my break fluid is fine its a 2016
#15 |
also those forks go all the way down till the top is flush with the trees.
