Old 01-05-2017, 03:31 AM   #1
jbfla   jbfla is offline
70 Series Dual Sport Tires
Where have all the 70 Series Dual Sport Tires Gone?
Notice the difference in size between the two tires.
(the picture is exaggerated because the CST tire is not inflated.)
The stock RX3 CST tire has a 70 aspect ratio.
The Shinko has an 80 aspect ratio.
There is about a 2 inch difference in diameter.
I bought the 1" lowering link and the narrow seat for my RX3 to bring the seat height down.
With the new Shinko it goes back up an inch.
The only 70 series dual sport tire that I could find is the RX3 stock CST tire in 130/70-17.
Other 70 series tires of that size are all street tires.
Something to think about when purchasing a new rear tire.
jb
2014 XT 250........
Old 01-05-2017, 04:20 AM   #2
pete   pete is offline
pete's Avatar
theres not meany for dirt /ADV... they put the rim to close to the ground at low pressure
high chance of rock damage...
I run 90 & 100 on my dirt only bikes ... can run below 10psi with out a worry of
rock damage to the rim....
CST "Ching Shin Tire" is one of the few that do anymore...
they do make quite a few quirky little tyres...
only one that springs to mined in the style you are after is the Avon trailrider 120/70/17
but they an't cheap...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-05-2017, 11:21 AM   #3
high chance of rock damage.....
Pete, thanks for reminding me of "airing down" the tires for serious off road riding.... and the danger of rim damage.
I had forgotten since most of my riding is on pavement.
jb
2014 XT 250........
Old 01-05-2017, 12:39 PM   #4
fjmartin   fjmartin is offline
On my Shinko 244s I go from 32/33PSI to 22/24 when I go off-road. I've done the same thing with the CST tires when just cruising around on forest service roads. I'd never thought about the aspect ratio in regards to rim damage based on how low you can take the pressure down. Interesting and helpful. Thanks!
2017 BMW F800GS Adventure
Old 01-05-2017, 12:46 PM   #5
Emerikol   Emerikol is offline
JB, I have that same Shinko 705 out back on my DR650. It's a great tire, but be really careful in the wet with it. It gets super slick and squirrelly when you lean it over at all. Even going straight and riding in the wake of the front tire it doesn't seem planted. Just my thoughts and personal experience, though. It may be different for a lighter bike with different tire pressures. YMMV. Happy Riding!
First Rule of Aviation:
-Never Pass Up The Opportunity to Pee
I was struggling to get my wife's attention; I sat down on the couch and looked comfortable. That did the trick!
My wife says I only have two faults. I don't listen and something else...
If at first you don't succeed, try doing it the way I told you to...
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 01-06-2017, 01:27 AM   #6
Thanks for the warning.
I have the 705 on my DR650 as well.
I have only occasionally been caught in the rain. Never noticed it being squirrelly, but that may be because I slow down, and am sensitive not to lean the bike any more than necessary.
jb
2014 XT 250........
Old 01-06-2017, 10:58 AM   #7
I'm really curious about the 705's. I don't want anything too aggressive because we spend 90% pavement, 10% graveled road. The upside is the stock tires seem to do very well for our needs, but I'd like to have other options without raising the bike height.
Old 01-06-2017, 11:49 AM   #8
The 705 is an 80/20, pavement/dirt, tire.
It definitely raises the seat height.
With my 30" inseam, I can barely tiptoe on both sides at a stop.
It looks like the stock CST tire is the only dual sport tire in the 130/70-17 size.
I thought the CST tire performed well and lasted a long time.
When I wear out the Shinko, I may go back to the stock tire.
jb
2014 XT 250........
Old 01-20-2017, 03:32 PM   #9
Here's a thought. Still a 70 series but 10mm wider per side (150/70). Think this would fit? I've gone wider tires on my big cruisers without an issue but not sure how it would work on the RX3. At least you'd have your same height, right? May be tough to get on the rim.
https://www.amazon.com/Shinko-Dual-S...YKNNAEN953V6H5
Old 01-20-2017, 03:50 PM   #10
2LZ, that tire is 2 sizes larger than stock.
When I checked the Shinko website, that 150/70 tire has a diameter of 25.28 inches.
The 130/80 tire that I mounted has a diameter of 25.20".
I'm getting used to the bike sitting higher, just worried that when I install the already purchased 19" wheel and tire, the front will be raised another 1/2".
When I wear out the 705, I will likely go back to the stock CST tire.
jb
2014 XT 250........
Old 01-20-2017, 05:10 PM   #11
jb
Yah, I have no complaints about the stock tires. Was just fishing for other options. Didn't Spud change his rear rim to accommodate other tire sizes?
Old 01-21-2017, 12:36 AM   #12
rjmorel   rjmorel is offline
rjmorel's Avatar
yuparoos. Spud's sticky on Warp 9 rim
http://www.chinariders.net/showthread.php?t=14974
Live Zong, and Prosper
Old 01-21-2017, 01:26 AM   #13
pete's Avatar
The Kenda 761 is in the same style & prise range as the Shinko705...
KENDA 761
SHINKO 705
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 01-21-2017, 11:18 AM   #14
Thanks, Pete.
But that tire also is not available in a "70" series aspect ratio.
jb
2014 XT 250........
Old 01-21-2017, 09:01 PM   #15
The Kenda 761's are what I have on Q and no complaints. I'm getting good wear out of them and they handle the paved twisties quite predictably.
