#31 |
you guys might try that dupont chain lube spray at walmart. don't have to remove anything. just use the plastic tube to spray some in to the top of the cable until it runs out the bottom like wd 40. go eat a sandwich and it will change inside the cable to a dry waxy/ pfe like anti friction coating on the cable. slicker than u know what! if you spray it on the concrete and let it do its thing, you can't hardly stand on it
![]() on a good std mcycle chain, you can approach the life of an O ring one ![]()
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
#32 | |
2016 CSC TT250 |
#33 | |
#34 |
DuPont Teflon Chain-Saver is awesome stuff. Excellent lube without the mess.
#35 | |
They changed the composition formula
![]() The new formula doesn't seem to last as long between applications. I was lucky to find several containers of the "old formula" online and stocked up. I wish DuPont would return to the old formula! ![]() |
#36 | |
Just FYI, Should know within a few days if the speed sensor i'm having built will work properly on the TT. Then the clusters i have will bult up and go! |
#37 |
With all the electronic stuff we have nowadays, why are we using a spinning cable in a sheath? That seems like late nineteenth/early twentieth century technology for god's sake. I'm guessing the German, Japanese and American bikes built now use a better technology?
2016 CSC TT250 |
#38 | |
#39 | |
2016 CSC TT250 |
#40 |
I've got one of mjstefs replacement speedo's for one of my hawks
#41 | |
That said, this could be the motivation I need to jump to mjstef's setup once it's done. Mrs. 2LZ really like the sweeping tach and digital speedo on the RX3 and this would cure that problem.
#42 |
Looking forward to the good word! :-)
#43 | |
2016 CSC TT250 |
#45 |
Yep, emailed him yesterday, cable shipped out already. Great service as always. We'll see if this one lasts.
