03-16-2016, 10:08 AM | #1 |
Who is interested in a Hawk OEM Tach Speedo cluster?
After about 2 weeks of back and forth with a manufacturer in China it looks like i will have a prototype replacement cluster with a tach to test shortly. This will have a wired sending unit from the wheel VS the speedo cable. I have another thread going on this but figured i would start a new one for interested parties. If the prototype works properly i will place an order for multiple units. I need an idea on how much interest their is for these. It looks as if they will come in at about $50-$60 shipped depending on the # i order. Post in this thread if your interested and i will fully review when i get the prototype in hand.
03-16-2016, 11:12 AM | #4 |
Likely NOT a gear indicator as that would take work inside the trans case but the neutral light will be there as well as high beam, turns, fuel gauge and trip odometer.
03-16-2016, 12:33 PM | #8 |
in for 1
the gear indicators don't use anything but the measured speed and rpm to estimate your gear (that is the programming bit, it needs to know the gear ratios essentially) combined with the neutral switch to know when its in neutral. nothing internal to the transmission.
-whatever you do, just be awesome. - 2008 Kawasaki Versys - 2016 CSC TT250 |
03-16-2016, 01:35 PM | #9 | |
Hmmm, I'll have to ask about that then........ |
03-16-2016, 02:15 PM | #10 |
there are aftermarket ones that use hall effect switches and a magnet on the shift lever to sense when you shift up or down. but that is so universal that I doubt this one uses that system. more likely it uses the calculation method using speed and tach.
03-16-2016, 07:19 PM | #11 |
I'd buy one if they work like butter for the Hawk
Paul Mann 2015 Haosen Hawk 1989 Kawasaki EX500 1991 Suzuki DR350 |
03-16-2016, 07:45 PM | #12 |
I'd be down!
03-16-2016, 09:00 PM | #13 |
I'll keep y'all informed. Getting close to the time of night i get e-mails from China so hopefully it will be good news tonight....
03-16-2016, 09:38 PM | #14 |
Gear indicator is found in most stock vertical chonda engine.
Most "变速鼓" https://huabmp.taobao.com/search.htm...E4%CB%D9%B9%C4 had that Brass tab / Some model lacks "档显" (the wiring) https://huabmp.taobao.com/search.htm...d=%B5%B5%CF%D4 ONLY
