Back Sprocket
Hi all
I bought back brake pads for my 2015 RX3 from the local Honda dealer, they're from one of their offroad bikes, Nissin I think. What I wanted to ask was which back sprockets have the same Pitch circle diameter and bolt centers? I'd like to experiment with smaller rear sprockets to see how high I can gear the bike up. My bike will rev right up to redline in top and feels like it would keep accelerating if I let it, so my plan is higher gearing. Although we're about 35 km inland we're still pretty much at sea level and as long as I don't start packing on the pork the engine seems strong enough. Anyone tried altering the back sprocket? |
I just ordered a front sprocket for a 90-98 DR350, I'll let you know if it works when it gets here.
I finally got around to installing the 1995 DR350 Front Sprocket on my RX3, fit perfect, only difference is there is no hole for the "keeper" to lock into, I installed it with some locktite, hopefully it'll hold.
I didn't think I have a drill bit that would drill thru the hardened steel of the sprocket.
Hi Everyone, Greetings from Colombia, sorry for my bad English, I would like to ask, what are the dimensions of the shock of the RX3, I'm thinking of modifying the suspension of this bike, I appreciate your response. Thank you.
I live in China and could buy n sell etc
Be a cool little sideline to what I do bike wise etc. |
I seem to recall an old post by Spudrider that said that the JTR811 was compatible. He used a 46 tooth version, but there are other sizes:
http://www.jtsprockets.com/catalogue/sprocket/JTR811/ I don't know how hard to get those are or if anyone can verify this information, though. |
sprocket
Thanks Mr Google says this is a standard Suzuki on/off road bike sprocket. We have a Suzuki shop in town
#9 | |
Peter Y. |
Control levers
After an unfortunate "dropped bike" I have discovered that the control levers, specifically the front brake, is an exact swap with a Suzuki GN125. Great news as this bike is sold worldwide (Well New Zealand wide anyway) Total cost of a set of new levers NZ$ 16.99 + 5.00 postage.
Another discovery the mirrors have a 10mm thread. Anyone need a set of mirrors with and 8mm thread? |
#12 | |
Very different and has tire pressure mon etc On RX4 needs full new loom etc These are common high grade version in china like the wheels or DOHC RX3 engine etc USA version is kinda more basic |
I have a cross-reference for the power connector on the left side of the dashboard, used for the OEM lighter/power socket!
PB045-02027 (female, this is the connector on the harness) and PB055-02840 (male, this is the connector that plugs into the harness). You can buy them here: https://www.amazon.com/dp/B08918WBW4/ and https://www.aliexpress.com/item/4001030259359.html Now you can easily add power to a handlebar accessory without wiring all the way back to the under-seat connectors, and without having to switch it from the right handlebar switch. If you want to run a phone charger and also have the OEM power accessory, you can buy connectors to make a splitter, keeping all wiring harnesses intact. (Which is always preferred to butchering a harness) Charles. |
#14 |
This appears to be the speedometer connector:
Male: FW-C-3M-B Female: FW-C-3F-B Available here: https://www.aliexpress.com/item/4000666843492.html And here: https://www.amazon.com/dp/B079LH1H1L A pair of these would make one of the speedo healer installations quite easy, without needing to cut the harness of either piece. Also easily removable when you want to sell your RX3 and upgrade to an RX4 ![]() I've got them on order and will confirm they're the correct part when they arrive... in a month... Charles. Charles. |
#15 |
Thanks for the research and links. Let's see just how long it takes to get the parts.
