07-15-2015, 09:15 PM | #1 |
lower ball joints
My lower ball joint seperated on a 110cc chinook ATV. can they be cut out ad a new one welded in? Otherwise I assume you have to replace the entire A-arm. Where can these be bought cheap
07-15-2015, 09:27 PM | #2 |
Not pressed in and out like cars/trucks?
07-15-2015, 09:33 PM | #3 |
the ball joint and the 2 little solid arms are all one piece and then welded into the tubing of the a-arms
07-16-2015, 12:43 AM | #4 |
I've seen them like that, and I shuddered at the thought of replacement.
I'd search on eBay first, to see if a complete arm is available at a decent price; definitely the easiest route. If not, I'd buy a similar ball joint that has the same dimensions and weld in a plate to accept it. If that's the route you go, make sure to buy a bolt-in joint.
