Old 05-06-2015, 12:45 PM   #3346
katflap   katflap is offline
katflap's Avatar
Rear Shock Rebound Etc.
The last time I had a bike with an adjustable rear shock was getting on for 25 years ago. If I remember correctly the bike manual had a table to refer to for setting it correctly.
If possible, could someone do an "Idiots Guide" that would be great
Or I will be stuck with doing months of something similar to this
Old 05-06-2015, 01:01 PM   #3347
I am going to start adjusting the sag and spring preload today. I will post a thread on this topic, including the rebound damping adjustment, in a few days.
Old 05-06-2015, 01:01 PM   #3348
How do people like their CSC centerstands? Are the new springs holding up? Please check in, and let us know.
Old 05-06-2015, 06:15 PM   #3349
fishman10   fishman10 is offline
fishman10's Avatar
the new headlight ,has two separate 'l,e ,d ,least thats the way it appears ,,,one at the bottom and where the standard bulb was.
2015 zongshen rx3,,(Sold),,,2016 bashan storm,,2005 Harley ultra classic.
Old 05-06-2015, 06:19 PM   #3350
fishman10's Avatar
Oh btw ,,,the centerstrand is a huge disappointment ,,it is poorly designed and hangs down much too low ,,if i ever would go offroad i would surely get stuck, as it will catch on everything you go over...I'll see if i can get a picture ,but its sitting in the shed and its raining......
Old 05-06-2015, 07:30 PM   #3351
rjmorel   rjmorel is offline
rjmorel's Avatar
I like my center stand Spud. Spring seems to be holding up so far for the 3 days I've had it. It doesn't hang down any farther then it's mount which is on all RX3s whether you have the center stand mounted or not. Don't think I'll ever get into a bad situation with it as my single track dirt riding, log hopping days are well behind me. For my intended use of chain maintenance it should be fine. rj
Old 05-06-2015, 09:21 PM   #3352
I'm failing to visualize how a bolt would hold your sprocket on. Can you post of pic of your installed sprocket for us?
My Honda CRF250X also uses a bolt to attach the counter shaft sprocket.
Old 05-06-2015, 09:24 PM   #3353
Originally Posted by katflap View Post
Reading In the CSC Baja blog about the bloke who lost his counter shaft sprocket nut I was a little surprised.
Not by the loss of the nut, but the fact that it was a nut and not a bolt.
Though I know the CSC RX3 has a number of upgrades / differences to the Honley RX3 (UK), I thought the engines were exactly the same.
This appears to not be the case ...
You are correct. I just checked, and my RX3 uses a nut to hold the counter shaft sprocket.
Old 05-06-2015, 09:25 PM   #3354
Thanks for the good report, Fish.
Old 05-06-2015, 09:26 PM   #3355
Thank you both for your feedback, gentlemen.
Old 05-06-2015, 10:44 PM   #3356
Today I started experimenting with the shock spring preload. Upon inspection, the RX3 shock absorber looks nice and beefy, with a large spring. After loosening the nut on the locking ring, I reduced the spring preload by moving the lock nut up the shock absorber. After three full turns, all of the preload was gone, and the spring was loose. Therefore, the spring preload on my bike, set at the factory, was at its minimum setting.
I tightened the spring preload back to the original setting, and added three more turns to increase the spring preload over the minimum setting. I went for a ride, and the shock performance was improved. However, I still need to add more spring preload before I find the optimum setting for my weight and preferred riding conditions.
I had to remove the battery and battery holder to gain enough access to loosen the nut on the locking ring of the shock. However, after that point, the rest of the process was very easy. I have a lot adjustment space available for the shock preload, so I am optimistic regarding the outcome. I continue to be impressed with the quality of this motorcycle.
Old 05-07-2015, 01:08 AM   #3357
G19Tony   G19Tony is offline
G19Tony's Avatar
I'd let you know, but I'm not having any luck getting my spring on. The tool I usually use isn't working for this application. I will say, that the spring mount and spring itself are much sturdier.
Honda CB300R ABS
Old 05-07-2015, 01:30 AM   #3358
Thank you, Tony. You might want to get one of these Tusk Spring Pullers.
https://www.rockymountainatvmc.com/p...pring%20puller
Old 05-07-2015, 01:48 AM   #3359
Tony, you can also insert a dime in between each coil of the spring. It will grow a considerable amount, allowing you to easily place the spring over the tangs. After it's in place, just pop the dimes out. Thin washers work as well.
Old 05-07-2015, 01:49 AM   #3360
Here you go
Thanks for the pic; that makes much more sense to me now.
