01-19-2015, 06:33 PM | #1 |
PZ30 vs Mikuni! Comparison with pictures
Here is a Comparison of the Mikuni 30mm clone and a KeiHin P30 30mm carburetor.
ID measurements The PZ30 measures 30.48mm inlet and 38.1 outlet Mikuni measures 30.353mm inlet and 39.37 outlet Now some side by side shots. Mikuni on left, PZ30 on right. The mikuni has 4 bowl screws the PZ30 has 3 The idle screws are different This Mikuni came with a lever choke, the pz30 was cable choke. They are interchangeable between brands. The Mikuni came with a nice coating of clear oil inside to keep everything in good shape. All edges smooth The PZ30 had a lot of rough castings spots and extra metal hanging off in places. I also found metal shavings in numerous places. I have already corrected all these problems before the pictures. Sorry. Inside of the PZ30 Jets are not labeled Inside of the Mikuni Labeled jets. Mine came with a 100main and 30 pilot jet Labeled jets. Mine came with a 100main and 30 pilot jet |
01-19-2015, 07:42 PM | #2 |
Awesome write up. Glad you posted this because I was thinking about upgrading mine.
Thank you, Dan |
01-19-2015, 07:48 PM | #3 |
i would suggest the mikuni for sure. easier to tune and jet
