relocation of ignition
My first post; I am adding a sidecar to a 2012 Genesis xm200gy-b and what to move the ignition, the black and red are connected together and the bike turns over and there is spark, what do I do with the black/ white and the green wire? It is going to be a keyless push button? Thanks Fenix
![]() ![]() I suspect the black/white and green wires are designed to ground the CDI unit when the ignition switch is turned off. If so, you can insulate the ends of the wires, and tuck them away, since you want a keyless, push button ignition.
Thanks ; will the battery still charge?
Yes, the battery should charge; I don't see why not.
Thanks Spud: do you think the bikes charging system will also charge a second battery on the sidecar for a radio ???
The stock one's output is WEAK:
250W (Stock: 93mm / 9+2) http://item.taobao.com/item.htm?id=2979440058 -- 180w (Stock: 88.6mm/ 7+1) http://item.taobao.com/item.htm?id=1651715694
#8 | |
What type of radio? Maybe just use a rechargeable UPS battery. I use these for power wheels. You could also add a solar panel charger. http://www.ebay.com/itm/12V-7-2AH-Se...item20d1c8617d
Do you want a radio for communications, or a radio for listening to commercial stations? In either event, I would use a radio with a separate battery.
HB, is this worthwhile? http://item.taobao.com/item.htm?spm=...0-bcfc7d165890
#11 | |
In this mod NEEDS these:
http://item.taobao.com/item.htm?id=17966778188|http://item.taobao.com/item.htm?id=999701426 Quote:
![]() Suitable stator in old rotor is the quick solution. --- 350W http://item.taobao.com/item.htm?id=18465032658
Thanks for the tips, HB. I wondered if a high current CDI and reg/rec would be needed.
