200 cc starting issue
so my bike was sitting outside under a buddies porch for about a year with a flat tire. i finally replaced the tube and got it rolled into my garage. I bought a new battery and rebuilt the carb.
so when i go to crank it with carb cleaner to see what its going to do after a year, the main ground wire melted off the insulation. i quickly turned off the key and replaced the ground with a wire of the same gauge. only when i hit the starter button does the circut get hot. otherwise all my lights, horn, etc still work. I assume it is a bad starter solenoid but not sure yet. anyone have any suggestions? I have a Fluke multimeter and lots of other electrical diagnostic equipment to use, i dont know what else i can test.
2008 200cc dirtbike |
I was able to fix it!
The issue was a corroded ground to the battery box. so i took it off and cleaned up everywhere that the bracket contacted the frame. then i tested it by only connecting the ground wire to the battery, then using the multimeter, i placed the red probe on the positive battery terminal and the black probe on various places on the frame/ engine block. I had 12.7 volts all around. and it cranks and runs with no hot wiring! now i have to tune the carb..........
Good work!
Good work. No better feeling than a free fix!
Happy to serve. |
Nicely done.
bucannon |
