07-12-2013, 01:56 AM | #16 |
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div> |
07-12-2013, 11:33 AM | #17 |
Have you removed the cover to see if either switch has broken wires? If so, they could be repaired.
07-12-2013, 11:59 AM | #18 |
for what they cost at saga we are just going to buy a new one for the 200 and the 150 got the spare that i had here.
07-12-2013, 05:29 PM | #19 |
hmmm ok got the filter installed but now it has no git up and go :(
07-18-2013, 12:54 AM | #20 |
changed the main jet to a .40 and moved the needle c-clip down one from middle and now she has the get up and go it was missing.
now there is a squeak in the rear that sounds like brakes are stuck on ....but their not
07-18-2013, 01:34 AM | #21 |
I do have the 130 slow jet as well ....i have it idling (to a degree). anyone think i should put the 130 slow jet in as well?
07-18-2013, 10:00 AM | #22 |
wow i must have been tired when i wrote that ...... have changed the main to a 130 and have not changed the slow yet
07-18-2013, 10:35 AM | #23 |
What were the original jet sizes?
07-18-2013, 10:47 AM | #24 |
unfortunatly there are no markings on the original jets.
I went on the advice of another forum that said that when you change to a uni filter to bump the jets in the stock carb up to a main .40 and a slow 130 (if needed)
07-18-2013, 11:06 AM | #25 |
You must still be tired.
I presume you mean a 130 main and a 40 slow. I'll check my spare carb and see what the jets are as a baseline. Those sizes sound a little large to me.
07-18-2013, 11:12 AM | #26 |
yes you are correct
07-18-2013, 11:55 AM | #27 |
ya this is how i wanted to spend my 4 weeks off.....fixing the wifes atv
07-18-2013, 12:04 PM | #28 |
I just checked, and the stock slow jet is 34 and the main jet is 103. It's feeding 150cc, and the only change you've made is a pod filter. I'd try a 110 main and the 34 slow jet. If it won't idle, try the 40.
07-18-2013, 12:16 PM | #29 |
do you know if saga carries jets?
I have to go there today to get parts for my friends beast.
07-18-2013, 12:58 PM | #30 |
i have officially lost my sense of humor
