05-07-2011, 06:01 PM | #1 |
Another find...Verucci Veneto? 49cc
Picked up a bike for her today...$200.
Its a 2005 model w/ the original tank of gas in it...bleecchh...its got 33 miles on it. Just pulled the tank off and tried to clean out the valve/fuel line...think the carbs gummed up too...if I have to I'll take it to the shop but does anyone have links to video on how to clean the carb? I checked on youtube but must have missed the one I needed. Pics soon. |
05-07-2011, 08:05 PM | #2 |
05-07-2011, 08:46 PM | #3 |
Remove the carb, take your time and remove the bowl from the bottom. Spray everything liberally with aerosol carb cleaner and make sure it's perfectly clean.
Sounds like a good score!
05-07-2011, 08:54 PM | #4 |
4 stroke
http://verucci.com/html/products/new...eto-VC50-C.htm The reserve valve in the fuel tank is blocked up a bit too I think...unscrewed it and sprayed some carb cleaner through it but I think there is a part that I can unscrew on the bottom too..going to take it all apart tomorrow after church :twisted: |
05-08-2011, 11:57 AM | #5 |
Good luck getting through Church without thinking about your new bike. I can never do it.
05-08-2011, 09:28 PM | #6 |
You remembered what day it was right?
05-08-2011, 09:31 PM | #7 |
That has a honda horizontal engine. Lots that can be done with that.
Does the carb resemble the one on your lifan?
05-09-2011, 10:05 PM | #8 |
Really looks like I could swipe the 70 off my sons Honda dirt bike and pep up the wifes scooter. Same style carb/motor pretty much. I dont remember the lifans carb...hope to get to work on it wednesday.
05-10-2011, 07:55 AM | #9 |
You can easily pep it up if you want. Carbs are cheap.
05-10-2011, 10:20 AM | #10 |
So are big bore kits.
05-10-2011, 06:10 PM | #11 |
I got a 110 parts engine and a 22mm carb. :wink:
05-17-2011, 10:06 PM | #12 |
Cleaned the carb today...and the fuel tank valve...fired up on first try...wife took it on a test drive...turns out its a two speed? weird. hits about 35-40mph right now. Needs more tuning. She was happy to be riding though.
05-18-2011, 08:37 PM | #13 |
That is pretty good speed for a 50cc engine. At least its flat in FL.
09-07-2012, 07:32 PM | #14 |
verucci vc50c HELP PLS.
hey did you notice any noises in 3rd and 4th gear i just bought one used it ran fine for a week then all of a sudden my 3rd and 4th gear started makeing noise like something had come off and it started losing power in those gears. so neadless to say its been parked for two days but i want to get it back on the road any help very apreciated
