Thread Tools Display Modes
Old 05-22-2011, 04:38 PM   #31
midlifekrisiz   midlifekrisiz is offline
couldn't locate my dremell to clean up the edges but that can be another project.
got it all bolted in place
took this
into this
one ratchet strap and this should work fine.
and I did get to test the winch today....took it out to the back yard , tied a rope around a tree, fed out some line, put the quad in reverse with the brake on and winched.......it dragged me and the bike accross the back yard all the way to the tree....mind you that seems to be quite taxing on the battery but the quad was charging and is now on a charger so it should be good to go.
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div>
Old 05-23-2011, 10:56 AM   #32
katoranger's Avatar
Most likely you won't be winching with the brake on and in reverse either.
Old 05-23-2011, 11:26 AM   #33
lol no your right but was the best way to test it in the back yard :wink:
Old 05-23-2011, 02:30 PM   #34
Was that with or without a snatch block?
Old 05-23-2011, 06:07 PM   #35
no snatch block just a rope around the tree and the winch hooked to the rope
Old 05-24-2011, 12:42 AM   #36
Then those are excellent results. A snatch block will double your pulling power.
