Clutch Lever
I just put together my lifan 200 gy-5 and I dropped it on it side and bent the clutch lever. Does anyone know where I can get a replacement?
--Matthew |
I would pull it off and head down to the bike shop and look for a universal replacement.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#3 | |
Frostbite "The beatings will continue until moral improves" |
Hi Matthew04833
If you heat it with a acetylene/oxygen torch, holding it in a vise or on the bike you will be able to bend it back with ease. a propane torch most likely may not get the aluminum hot enough unless you have a special tip for that style torch. Remember not to over heat it as you can easily melt the lever. I have them in stock if you need a new one.
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
Clutch Lever Tip 'O' The Week;
Running bark busters makes bent and broken levers a thing of the past. Dont like bark busters? Try a few wraps of teflon sealing tape around the bar underneath the perch. Teflon sealing tape is in the plumbing section of your hardware store. It provides a slick surface that will allow the perch to slip on impact, rather than bending or breaking the perch/lever. You can knock the perch back into position, make sure to hit the perch and not the lever. Many aftermarket perchs use a telon liner to accomplish this. |
#6 | |
Great Advice!!! Well done
The destination is merely a by-product of the journey. '06 KLR650 '06 XT225 '92 XT225 Serow ( MBD.... Multiple Bike Disease...) |
