Headlight Dims When Braking
I have a LF200GY-2 manufactured in March 2006. Curious that my headlight dims when I brake and stays dim when the brakes are released. I have read the post where the headlight brightens when brakes are applied but mine does the opposite. It does not seem to be a pure load issue since the headlight stays dim when I release the brake. Is this a common problem?
Does one of the brake light switches maybe stick when applied? That plus a weak battery would explain the symptom.
Happy to serve. |
#3 | |
Re: Headlight Dims When Braking
![]() ![]() Spud ![]()
Bad battery is my guess, Or bad connections at the battery or behind the light.
Bad battery or maybe a bad regulator. The alternator should be able to provide enough voltage to maintain the headlight when the throttle is released (and the brake is applied), but perhaps the regulator isn't conditioning the power like it should.
Since you said that the headlight fails to return to a bright state upon releasing the brake, I'd start with the battery. What is the battery voltage at rest and when running?
Measure the battery voltage after a good run when it should be fully charged. It should read 12.5 or 12.6 volts with everything switched off. Turn on a heavy-ish consumer like a brake light (21w), and the voltage shouldn't drop below 12 volts. If it does the battery is sulphated and has a high internal resistance and can not hold a charge.
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
Might be the battery
Thanks all for the replies. Good community here for these bikes considering the parts availability, product standards, etc. I just bought the bike used ($900 with 285 miles or maybe kilometers?) and it might have a weak battery. I hooked it up to a battery charger last night and the symptom went away. I will let it charge fully and report back. I bought a battery maintainer and wired a permanent connector to the battey so I could keep the battery in better shape. I do this on my other bike as well.
By the way I read somewhere that that some of these bikes have a KM odometer and a speedometer in MPH. I will compare a known distance for mine and verify. I do not really care for the bright blue color of this bike so I was considering camo paint or a wrap like Camoclad. I am not very artistic so the Camoclad my be better for me. Does anyone have a link to pictures of a bike using the Camoclad product? I can get a 4ft by 5ft sheet for under $80. Might make a Ducks Unlimited Special Edition! |
Happy to serve. |
My GY2 reads in MPH speed and Kilometers on the odo.
Allen
Display Modes | |
