Old 09-27-2024, 11:55 PM   #1
darren   darren is offline
no spark
picked up a kids atv serial #L5kgue828771008229 replaced wiring harness and all components with new from amazon still has no spark i have 2 connectors blue, white and a green wire open i think its lights and a black and yellow with green stipe connector in the front harness not sure if its foot brake and a green brown and yellow with green stripe connector and a black and green connector not connected in the rear of harness engine rolls over when i squeeze the front break but no spark is the coil somehow grounding out
Old 10-01-2024, 09:40 PM   #2
shad88   shad88 is offline
None of those connectors will cause no spark. Did you replace the stator? If it's a 2 pole stator I've had a bunch of them not adjusted properly over the last couple of years.
Old 10-05-2024, 11:06 PM   #3
yes its a new 2 pole stator
Old 10-20-2024, 12:05 AM   #4
stator gap good any wiring diagrams available for these bikes maybe i'm missing something that should be connected
Old 10-21-2024, 08:36 PM   #5
found the problem a defective new cdi
Search this Thread:
Advanced Search
Display Modes
