Old 06-29-2024, 04:59 PM   #1
AngryDick   AngryDick is offline
Stripped Threads
I stripped the threads on one of the inserts on the tank for the side panel on a Templar X, Any fixes anyone can suggest?
Thanks!
Old 06-29-2024, 08:21 PM   #2
tap new threads, and use a larger diameter bolt.
Old 06-29-2024, 10:02 PM   #3
Fast_Freddy   Fast_Freddy is online now
Fast_Freddy's Avatar
Get a slightly larger self-tapping bolt.
22 Templar 250
Old 06-30-2024, 10:05 AM   #4
GypsyR   GypsyR is offline
GypsyR's Avatar
I always feel a bit skeezy doing it but sometimes you can get away with using a similar sized coarser thread SAE bolt. I never used a self tapper like Freddy suggests above but that makes sense as an easier way to so the same thing. Most self-tappers seem to be SAE. if the fit doesn't seem tight enough, a dab of blue LocTite should take care of it.
The actual proper way would be drill it out, retap it for a Timesert or Helicoil, and then use an original type bolt again. Nice and professional, but really an overkill solution for this particular problem.
2023 Templar 250 X
Search this Thread:
Advanced Search
Display Modes
