How to Prime New Hawk Engine?
Hey everyone! I just picked up a used hawk with a blown engine last Thursday. I've gone through all the electrical and am now ready to pull the trigger on a replacement engine from txpowersports. I do have a few questions, however.
1) Does the engine come primed with oil and ready to simply drop in and start? 2) If not, how would I go about priming the engine? Pull off the spark plug wire, disconnect the fuel line, and crank it? Thank y'all for the help in advance! |
It may come with oil. But after you install the engine, drain the oil. Replace it with good oil (about 1 quart).
Regarding starting, if the carburetor float bowl is filled with good fresh fuel (turn on the petcock), the engine won't need priming (fuel). Just use the choke. |
If you really want to prime it, pull the plug, leave the ignition off and with oil in the motor simply turn it over for 10 to 15 seconds, give it a break, repeat. After that simply put the plug in and go to start it like normal.
Although the oil is pumped, it's really more of a "splash" oil system, so hand-turning the engine won't do a whole lot to distribute the oil everywhere it goes. Make sure it's full of good oil and start it. Then it'll get splashed around in a second and a half or so.
#5 | |
It definitely can't hurt to prime it.
Thank you everyone for the help! Just a week or so until I can order the new one, I’m a lot less nervous about it now.
Display Modes | |
