Does anyone have an idea why my new Hawk 250 wont shut off the engine when I turn off the ignition or hit the kill switch? It just keeps running after I turn it off or hit the kill switch and I stall it out and can still start it with the kick start when the ignition is off. Any help would be appreciated.
Suspect bad ground, here's a thread with wiring diagram you can see how the kill and ignition switch interact:
https://www.chinariders.net/showthread.php?t=16065 |
Definitely a grounding issue. From the way you're describing it, I would guess it's downstream from the ignition switch, and not between the ignition switch and the kill switch. You'll have to check everything out one wire section at a time.
Found the problem. Thanks for the wiring diagram. It was a wire not plugged into the CDI.
Tags |
ignition wire, kill switch |
Display Modes | |
