Tao Tao DB14 rear brake issue
hello,
I bought my son a DB14 pit bike for his birthday a couple months back.very long story short, rear brakes were locking up after they got warm. tinkered with them and could not get it right. called company , they sent new rear brake assembly and pretty much the same thing. they work until he uses them a few times . then they lock. bled off a little fluid to see if that would help but no luck. any ideas? My son and I are really new at this ![]() Thanks in advance! Norm (xanders dad ) |
You will need to make the adjustment at the brake peddle so that it's not putting pressure on the master cylinder. Make sure the shaft is fully returning on the master cylinder. The adjuster is on the end of the shaft.
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-27-2017 at 10:30 AM. |
I think that is adjusted right but i will give a second look at it. I guess I can loosen it a bit and see if that helps. there is rediculously little info on these bikes. no instructions for anything, ever lol
Display Modes | |
