Apollo 250
Does the Apollo 250 have a spark arrestor? if not what is an aftermarket alternative that will fit?
If it doesn't, the FMF TC2 is a good, economical choice. Shop around for the best price.
http://www.fmfracing.com/Products/MX/62
I was looking into that exhaust but it says that it is mainly for 2 stroke motors so I wasn't sure if it would be an issue on this bike or if I should just spend the extra money for the 4 stroke model?
That really means nothing. You can take it apart and wrap it with four stroke packing if you wish, but I wouldn't do that until the original packing is wasted. Spud has many, many miles on his TC2, and that's on a four stroke China motor. Read all about it: http://www.chinariders.net/showthread.php?t=5974
I have over 1,200 miles on the TC2 muffler on our Bashan... exhaust note sounds great... it was light and easy to install... and after I bought a propper 1 1/4in exhaust clamp it stopped falling off every time I raced up those bumpy Rocky Mountain trails
![]() ![]() Gave the bike a much better feel across the entire RPM range, HP / Torque feels great even down low on our bike ![]() You can jet the bike a bit rich to make it sound "Mean like a big Harley! GRRR!" or you can jet the bike perfect and it will have a nice "thumper style rumble" to it ![]() One of the better mods done to the little Bashan was ditch the stock muffler for a lighter Muffler with a Spark Arrestor ![]()
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
Thanks guys that's exactly the info I was looking for! Yeah I have to ditch the stock exhaust because all the forest roads require a spark arrestor (and not a homemade one) to be legal.
I have FMF TC 2's on all of my rolling stock BUT the TT250.
Great little muffler, easy to mount, is relatively cheap and best of all, it's a USFS Approved spark arrestor. I'm not sure how the Apollo header pipe is configured though. May take some imagination to mount.
Yeah I bought the TC2 that claims to be universal so we will see what it looks like when it gets here. I have a mig welder too so I should be able to make it work.
Sooo I was putting the clutch on a new set of handlebars and the electrical wire that connects to the clutch kinda exploded out of the clutch and all the little parts that were in it were lost in another dimension.... I was going to change the clutch lever to an aftermarket one anyway but the one I have doesn't have any setup for electric wires to connect to... I am guessing it has to be some sort of safety setup so that it won't start if the clutch isn't engaged. I don't really want to keep the wiring if I can help it so is there a way to bypass it?
#10 |
Bypass = http://www.chinariders.net/showpost....2&postcount=14 Learns how the E-start system works & made BOTH +/- wires connect to Starter solenoid possible when pressed start button. How to join wires together (Solder/ Plumber's tape + Electrical tape / crimp ) is ur own choice...
#11 |
Does anyone have a link for the pilot and main jets that fit the mikuni vm26 clone? I am having a hard time finding the correct jets.
#12 | |
they work one of 2 ways.... trace the wire to the conector or plugs... disconnect them see if it starts... If not ... then put a jumper wire in to connect the 2 wires... ..
#13 |
Yeah I just connected the 2 wires and it is starting just fine like that so I think I will just secure the wiring and call it good.
Display Modes | |
