Old 06-11-2007, 04:36 PM   #1
akron   akron is offline
LF150GY stutter above half throttle
I am new member and have a new (200 mi.) 150. It hesitates or misses above half throttle. I weigh 220 lbs. Is this a carb adjustment issue, a break-in issue or a spark issue or simply not enough info.
Old 06-11-2007, 05:03 PM   #2
Probably the air/fuel screw. How many turns do you have it out now?
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 06-11-2007, 05:18 PM   #3
As far as I understand air/fule adjustments - the visable screw (pointing down) is only for idle up to 1/4 throttle.
Old 06-11-2007, 05:33 PM   #4
CathastrophiX   CathastrophiX is offline
Raise the needle, check that your air filter is connected properly.
"Failure is always an option!"
Qingqi QM200GY -06
Old 06-11-2007, 05:42 PM   #5
I will check the air filter. My grandparents (both sides) were Swedes.
Old 06-11-2007, 05:51 PM   #6
Where from? Do you know if they were relatives to Spinnel-Anna?
Qingqi QM200GY -06
Old 06-11-2007, 07:07 PM   #7
mother's side - Johnson (of course) Skone, father's - Bing - military issue (birth name - Svenson - of course) area? More questions: the manual seems in error regarding fuel shut-off valve lobe positions: lobe up - ? lobe forward (side) - ? lobe down - ?
Old 06-12-2007, 08:37 AM   #8
red2003   red2003 is offline
Fuel shut off needs to be up or down. The middle position is OFF. Sounds like the engine is still breaking in. I would check your air filter connection as suggested first. If all looks well there, take the bike out and run it at that stumble point for a while, then immediately shut it down. Pull the spark plug and see how it's burning. I bet it's gonna be pure white indicating a lean condition. If it's not lean, then next thing I would check is spark. Plug or CDI might be bad.
Old 06-12-2007, 09:49 AM   #9
This place is great, a wealth of info for us china bike owners. Thanks for the responses. Now I need a weekend for diagnosis.
Old 06-12-2007, 11:10 AM   #10
Best of luck with it, and keep us informed!
Old 06-12-2007, 01:27 PM   #11
Johnson and Svenson is "americanized" versions, they probably changed from Jonsson and Svensson. Skone=Skåne? Do you get new names in the US military? When i did my militaryservice we had some guys with "war like" names (their real birth names) for example:
Krig=War
Strid=Combat
Krut=Gun powder
Qingqi QM200GY -06
Old 06-12-2007, 02:06 PM   #12
At the time, when my grandfather (or greatgrandfather) entered Swedish military service, last names were issued to help distinguish servicemen. There were too many with the same names. Upon leaving, the servicemen could choose to keep the issued names. This is how I understand the retelling of family history. Your Swedish spelling of names and Skone is accurate, I can readily assume. As for my bike, it awaits insurance and a weekend of testing.
Old 06-13-2007, 09:42 AM   #13
Fuel line valve positions
Point of clarification - fuel shut off valve: which position for reserve - lobe up or down?
Old 06-13-2007, 03:17 PM   #14
On my bike it's the "handle" upwards for reserve
Qingqi QM200GY -06
Old 06-20-2007, 02:36 PM   #15
Resolution was simple - replace the spark plug. It didn't look too bad on prior inspection but KISS procedure told me to start cheap. It worked. If anyone else has a Lifan LF150GY, I'd like to hear about it.
Search this Thread:
Advanced Search
Display Modes
