04-08-2017, 11:22 AM | #91 |
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
04-09-2017, 11:35 AM | #92 |
Cool
2016 Green Bashan Brozz. |
04-09-2017, 08:55 PM | #93 |
04-10-2017, 10:39 AM | #94 |
That is a COOL tailbag! Let us know what you think of it and how it mounts up!
04-10-2017, 06:54 PM | #95 |
Look what showed up today!!!! SO very comfortable. My BT Intercom will be here on Wednesday, so I'll have to get that charger up and mounted to go for a spin....
04-10-2017, 10:37 PM | #96 |
You are definitely partying like a rock star!
04-11-2017, 07:12 AM | #99 |
I got the same headlight as you only mine is a 5 cob. I found that I had to rotate it 180° in the little adapter to get my beam to point towards the ground rather than in the air. Not sure if yours will be the same. Just a heads up.
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
04-11-2017, 07:29 AM | #100 | |
What did you rotate 180 degrees?
2016 Brozz |
04-11-2017, 08:01 AM | #101 |
When he says 5 cob he is saying 5 leds. I have the same light and I ended up gluing the plastic adapter from the led light into my headlight housing. I find that having 2 led pointing up with one pointing down works best. It might work differently in your headlight housing.
04-11-2017, 10:36 AM | #102 |
Yes, 5 LED's rather than 3. Figured more was better?? lol. I found the low beam (your 2 leds) need to point to the top of the housing to reflect downward. I did not have to glue anything on mine. Comes with 3 adapters. I took the one that fit the headlight housing and "clicked" it onto the LED Bulb. Then installed the bulb as you normally would. I did cut a large circle out of the center of the boot to allow airflow so the fan could do its job.
04-11-2017, 03:22 PM | #103 | |
Thanks
04-11-2017, 03:32 PM | #104 | |
http://www.ebay.com/itm/252471031075...%3AMEBIDX%3AIT
04-11-2017, 06:05 PM | #105 | |
Display Modes | |
