#76 |
Is this the same LED as the CSC bulb? Sure looks similar (plus you get two for $32).
https://www.amazon.com/dp/B01DTXTDD4...IRX9ZQNF&psc=1
Newest machine: 2020... Oldest: 1916'ish |
#77 |
It looks pretty simmilar to the CSC bulb.
But... seems to be these units only provides one beam (no Hi/Lo differentiation). ![]()
______________ - ex Honda MB100 (1981) - ex Honda Nighthawk 250 (1991) - ex Honda Storm 125 (2009) - ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb) Benelli TRK 502 (2018) |
#78 | |
How noisy is the fan on your Hikari bulb? Mine is quite loud, kinda drowns out the fuel pump when I turn the key on. That extra sound could take some getting used to, but one thing is for certain- never have to worry about accidently leaving they key on and draining the battery! |
#79 | |
From my point of view, living at a dusty area, the sounds acts as a kind of "LED cooler fan working ok" indicator. ![]()
#80 | |
#81 | |
![]() An interesting thing I´ve found on these lamps: they are rated 30W low beam and 30W high beam; the measurements I´ve made said it is correct. However, when turning on both beams at the same time, it only draws 48W, instead of the theoretical 60W total. The Amazon product info and the leaflet says something about this.
#82 |
I keep meaning to post that I have installed the CSC LED headlamp and it seems to be a LOT brighter than the original. I do have photos - I just need to get them loaded so I can post them here
#83 |
Photos
![]() The new setup is a LOT brighter than the old...I should have taken a photo of the garage door with the light on it - that made it much more obvious than taking a photo facing the bike... ![]() I had installed a higher wattage halogen in the original headlamp and you can see that resulted in bubbling of the reflector (I did not cut a hole in the back of the headlamp housing when I installed the brighter bulb) ![]() Here are the 2 headlamp housings side by side and the new LED lightbulb ![]() Installation went easily, following instructions by Detours combined with shared higher in this thread |
#84 | |
And lest you think it is just Chinese bikes that suffer this affliction, I recently added a 2015 Versys 650 to the stable and it suffers the same problem, despite the high and low beams being separate assemblies. In fact, the damn high beam indicator on the dash is brighter than the high beam bulb itself, which appears to literally do nothing to increase light output when turned on. And no, it isn't burned out. Going to add some of the Genssi Elite H7 LED bulbs that Detours found to it as I ride at night a lot, especially in the summer. |
Display Modes | |
