#62 |
I've yet to experience a cable failure onmy 250, but I alsol ubed 'em up quite well. I did however experience a odometer failure; the speedo was still working. I replaced the stock speedo with a Lifan cluster with a tach. Problem solved.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#63 | |
#64 |
They is some sellers like www.hooperimports.com that has them but sorta of expensive.
I listed an ebay link to a guy parting a bike with 64 miles on it that has a speedo/tach combo. Look in the forsale section. Allen
#65 |
It was an E-Bay part....Someone parted out a bike.
#66 | |
Do you have a photo of where to apply the grease. Stupid question I know, but I am a first timer. (Or, as I say in the training classes I conduct, "There are no stupid questions, only stupid people asking them.") Thanks |
#67 |
I Think
Where the cable meets the wheel/ But it might be where cable meets the speedo. Both places are a good spot for a little grease, along with the cable if it pulls out. Just about anything that moves or rotates inside a sealed housing is a good spot for lube. What lube you ask?? Personal preference.. I'd use lithium grease. But that's just me.
IronFist ___________________________________ The "chain" of command is used for beating spammers. ___________________________________ |
#68 |
what's the best way to lube the cables? do you have to take them out of the rubber and grease by hand with a heavy lithium grease? I would imagine just spraying something like wd40 down at the levers wouldn't last very long
#70 | |
I'll see if I can dig one up.
Frostbite "The beatings will continue until moral improves" |
#71 |
frostbites above new bike prep check list isnt working link..
I am gtring to find the needle valve mod.. anone have a link for it.. tried search for my bogging problem to no avail |
#72 |
That was the old forum software, and the post was from 2008. I'll see if I can fix it.
#73 |
We will have to look. Some of the links are not working after the new site came up.
#74 |
I pointed the link in the Tech Sticky to the first page of this thread. I hope that is the correct fix.
#75 |
Still waiting
For my bike but: Its is still under a week since I placed my order. As this is an assembled bike from Venom Motorsports; Most would check the oil and tire pressure.No I am going to attempt to go pretty much as how a correct set- up should go in addition to some simple front suspension improvements. Dain and replace with 15 weight fork oil., Attempt to see if I can do the $15.00 fork mod and or attempt to induce preload.
Remove and pack both sets of wheel bearings and axle and same with a good slathering of greese to the swing arm axle. If this appears do able I can drill and tap a zerk fitting for further lubing the swing arm. Disc brake caliper mount bolts. I see a number of complaints ere so of course. loc tite.. I am going with the blue. All engine casing and any bolts I find will get a dab of the blue. I am thinking of including liquid electrical tape to any exposed wire connections (I live in western Oregon). So I will be running in damp conditions (often). A product that I have found a lot of use for is Flex Tape from Flex Seal.. The guy in the screen door boat ![]() Change the engine oil. I am going with Rotella 15w40 and yes I used that in my big trucks back when I worked ![]() I was thinking of soaking the chain in gear lube. But at this time don't feel inclined. I remember the days of heating up the pan of Castol-parrafin? chain lube and dropping the chain in until it had partially hardened. No chain problem with 10's of thousands of miles on those bikes. Yep! lube clutch, Brake and throttle cables.. I am going with Hi Temp marine grade grease. Since once I take this outta the cage (When it arrives Hint-hint Road Runner!) I can roll this into my kitchen ![]() Hope this gave you some good info. |
Display Modes | |
