06-19-2024, 11:11 AM | #586 |
Valve Adjustment comments
I just completed a valve adjustment checkup on an early edition of the KPX 250. A few comments:
First, it was easy to remove the front rack mounts and underlying bolts that hold the seat on (loosened the rear rackmounts bolts to tilt the rack). Then the battery cover and same panel on the other side is easy to remove with 4mm (I think it was 4mm) allen wrench and philips screwdriver, and the air louvre wings come off with 4 allen bolts as well. *The fuel tank is one of the easiest tank removals I have EVER done. Nice engineering Lifan! The photo was taken after reassembling looking up at the fuel pump from the stator cover. -there are two connections there on the left side you can remove first. 1) the fuel line (right red circle), which is released by pinching the connector (flat square surfaces on sides). It slides back (have a rag there for fuel in the line-but the fuel pump side stays sealed!), 2) The power supply line to the fuel pump (left red circle) is in the front of the thing, also easily removed by lifting (back) or pressing (front) of the tab. DONE. The sender line for fuel gauge is under the tank, so -Remove the two 8mm bolts and gently move the tank back to expose the fuel gauge sender connection. Disconnect that and the tank should be placed on a sawhorse to avoid dinging the seams or damaging the fuel pump connections. Jerry has a complete video on doing the valve adjustment so go with that. Intake clearance 0.08mm (about 0.003") and exhaust clearance 0.10mm (about 0.004"). ONE other thing I ran into was the bolt holding the rear cap ran into interference with the rear engine mount (photo below). The threads are 20mm, so you can get a 15mm replacement if you are so motivated. I was able to get it off, and threaded back on so this may be just an optional replacment. You could shave the bolt down a mm or 2 and file the threads clean instead:
-NOS 2020 KTM 250SX (2-stroke motocross) Last edited by Thumper; 06-19-2024 at 02:56 PM. |
06-19-2024, 11:15 AM | #587 | |
2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 07-26-2024 at 03:32 PM. |
07-11-2024, 06:12 PM | #588 |
Just ordered my Green KPX250 from Venom.
Excited! Just ordered my assembled KPX250 from Venom today. Never had a Chinese bike before, always went with Suzuki. I am a big guy, so maybe I will need to upgrade the shocks. I am a light use rider, only easy trails and back roads through the Ozarks. Robbie
07-11-2024, 06:28 PM | #589 | |
07-12-2024, 07:58 AM | #590 | |
07-12-2024, 08:03 AM | #591 | |
07-16-2024, 12:24 AM | #592 |
Newest update on the 2024 KPX 250
On Mon, Jul 15, 2024, 12:15 PM Mark Venom Sales <mark.venommotorsports@gmail.com> wrote: Hello there, Congratulations on your purchase! The KPX is the newest model out and is a 2024 year model. We have them in stock, and your order is currently undergoing full assembly and testing. It will be departing close to middle to end of this week! Once it ships, we will update you via email with a tracking number. The transit time from there will be between 4-7 business days. You will also receive a phone call to schedule the drop-off appointment once it arrives in your city. Thank you for your patience, and we hope you enjoy your new motorcycle! Best regards, Mark G. Venom Motorsports USA Mark.venommotorsports@gmail.com 1-855-984-1612 1380 Caldwell Cir, Anaheim, CA 92805 VenomMotorsportsUSA.com Yes, the new 2024 models do not have that issue, and it shouldn't be a problem for you. The manufacturer has since fixed that slight error in their models, so you can expect smooth performance without idling problems. Best regards, Mark G. Venom Motorsports USA |
07-16-2024, 07:44 AM | #593 | |
07-17-2024, 02:57 PM | #594 | |
I actually took a box end wrench and shaved it down with a grinder to fit. After that it was easy enough to remove and re-install the bolt. Last edited by JerryHawk250; 07-26-2024 at 03:32 PM. |
08-02-2024, 04:37 PM | #595 |
Update: The bike arrived fully assembled. Started up, ran a little rough for about 3 minutes, then fine. I have only driven it about 40 miles so far. I weigh 325lbs, so I had to adjust the rear shock. 325 is pushing the limit on this bike. Luckily, I am a easy rider and usually only drive down paved back roads.
08-13-2024, 02:17 PM | #596 |
100 miles on the bike. 69 mpg. No problems with bike. I drive down 2 miles of dirt road to get to my house. The tires are a little squirrely. The shocks are not stout enough for potholes with my weight. The seat height is perfect for 6 foot, 325 lbs. The bike has plenty of power for casual riding. The bike handles great. I like it better than my 2012 Honda XR650L. It seems just as solid and the weight on the 250 is distributed better. Both bikes weigh about the same, but the 250 feels a lot lighter. So far, definitely worth the money. It does not feel like a cheap bike. It handles very good on the asphalt.
08-13-2024, 02:23 PM | #597 | |
08-13-2024, 08:31 PM | #598 | |
2023 Hawk 250 from XPRO off of Amazon MOUNTAIN MAN RC + MOTO on YouTube "If there were more bloody noses, there would be less wars." - Hagbard Celine "Someday, after mastering the waves, the winds, the tides and gravity, we shall harness for God the energies of love and then, for the second time in the history of the world, man will have discovered fire." - Pierre Teilhard de Chardin |
08-17-2024, 03:28 PM | #599 |
not yet, but I can tell you 0-50 smoothly, then slowly up to 60. The fastest I have been is 64 so far.
08-17-2024, 06:08 PM | #600 |
Most bike suspensions aren't setup for us larger guys. Especially us enormous Dan's.
We fit the seats, not the shocks
Display Modes | |
