10-11-2014, 12:42 AM | #586 | |
I know Zongshen manufactures good engines. I also know Zongshen manufactures strong frames. Here is a link to the Zongshen RX3 frame sold at Taobao. http://item.taobao.com/item.htm?spm=...37&ns=1#detail The RX3 frame is very similar to the frame of the Zongshen ZS150GY-10. http://item.taobao.com/item.htm?spm=...7-7f6610681917 Notice the strong subframe on both motorcycles. My Honda XR650L has a notoriously weak subframe, which frequently fractures from carrying moderate loads. I have loaded my Zongshen 200GY-2 with heavy loads on many multi-day trips, and it has never complained. The review mentions that the lower frame rails are bolted, rather than welded to the downtube. However, I think this is an advantage, rather than a deficit. If necessary, it will be much easier to replace the lower frame rails, rather than trying to repair them. It is certainly not difficult to secure the lower frame rails with red loctite. If still concerned, one could add lock nuts. Also, it is very easy to periodically inspect the bolts for tightness.
10-11-2014, 12:53 AM | #587 |
I thought the same thing when I read the article. Everyone had a different take on things though, so what works for some doesn't work for others.
Current Motos: 2015 RX3, 2016 CSC TT, 1975 Honda XL250 |
10-11-2014, 01:12 AM | #588 |
I was also pleased to hear the good review concerning the quality of the switchgear, and the plastic.
Both of these items have been of significantly lower quality on previous Chinese motorcycles.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 10-11-2014 at 03:05 AM. |
10-11-2014, 01:21 AM | #589 |
The ADVPulse review also mentions the single-cable throttle as a deficit. However, my Honda XR650L has a two-cable throttle, and I much prefer the single-cable throttle on my Zongshen ZS200GY-2.
10-11-2014, 01:29 AM | #590 |
The ADVPulse reviewer also wonders if the front axle is too small. Considering my ZS200GY-2 has the same 37mm forks as the RX3, I'm betting the axle is also the same size. I have never had a problem with my Zong's front axle, and I have ridden the bike hard for over 67,000 miles.
I also like the odometer sending unit on the front hub. Many other bikes link the speedometer/odometer to the gear box. If you change the counter shaft (C/S) sprocket on these bikes, you need to buy an aftermarket, electronic gizmo to correct the speedometer/odometer. We won't have this problem with the Zongshen RX3.
10-11-2014, 01:41 AM | #591 |
The review also describes the shock link as being manufactured from 'bent sheet aluminum.'
However, you can see the shock link is a single unit, which is welded and reinforced at the front. I don't anticipate any problems with this shock link. As with my Honda CRF250X, the entire, lower shock linkage of the RX3 should be periodically disassembled for inspection, and lubrication. If the shock link suffers damage, it will be easy, and inexpensive to replace. Also, I don't doubt Zongshen will upgrade the design of the shock link, should it prove to be unreliable.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 10-11-2014 at 03:07 AM. |
10-11-2014, 01:44 AM | #592 |
I really like the digital dashboard on this Zong.
Also, the 1-inch, big bar handlebars are an especially nice touch.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 09-18-2015 at 03:16 AM. |
10-11-2014, 01:58 AM | #593 |
Personally, I prefer a serrated pad on the end of the brake pedal.
However, it shouldn't be very difficult to add that item to the RX3 brake pedal. Given the shape of the exhaust header, we will probably need to use a funnel to fill the crankcase with motor oil. However, that is not a big problem.
10-11-2014, 02:39 AM | #594 |
Pleased with all the other, nice features on the RX3, I apparently failed to notice the very nice, black, anodized rims and hubs...until now.
10-11-2014, 03:12 AM | #595 |
The Zongshen RX3 is a very attractive motorcycle. More importantly, based upon my experience with my Zongshen ZS200GY-2, I am confident the RX3 will be a strong and reliable motorcycle.
10-11-2014, 06:51 AM | #596 |
Searching Taobao, I discovered the officially designated, Zongshen, 5W/40 motor oil.
http://item.taobao.com/item.htm?spm=...70&ns=1#detail Contrary to the naysayers, I use Mobil Delvac, 15W/40 motor oil in all my motorcycles, including my CRF250X, were the engine can turn 12,000 rpms. My Zongshen 200GY-2 has traveled over 67,000 miles, and it also gets 15W/40 motor oil. I am going to use Mobil Delvac, 15W/40 motor oil in my Zongshen RX3, also. Anyone interested in learning more about motor oil for motorcycles might enjoy reading the following threads. http://www.calsci.com/motorcycleinfo/Oils1.html http://www.calsci.com/motorcycleinfo/Consumables.html
10-11-2014, 07:02 AM | #597 |
The coolant overflow bottle is attached to the inside of the right radiator of the RX3. Here's a link to the right radiator on the Taobao website.
http://item.taobao.com/item.htm?spm=...06&ns=1#detail You can see the bottom of the coolant overflow bottle in the next photograph, which shows the front underside of the motorcycle, viewed from the right side. I surmise it is a little difficult to access this overflow bottle. However, I don't think we will need to service it very often. The RX3 has two radiators, and each radiator has its own fan. The Silk Road Rider reported his RX3 never overheated, and he appreciated the engine coolant display on the digital dashboard. The RX3 is loaded with virtually every standard feature you could wish for, except hand guards.
10-13-2014, 12:27 AM | #598 |
Here is another view of the shock link/dogbone, and the lower shock linkage.
Once again, the shock link/dogbone looks very strong to me. I don't anticipate any durability, or reliability problems from this part.
10-13-2014, 12:41 AM | #599 |
Every year I remove the lower shock linkage from my Honda XR650L, and my Honda CRF250X. Neither of these motorcycles has grease zerks on the shock arm/knuckle. My CRF250X also lacks grease zerks on the shock link/dogbone.
I use the techniques in the following video to inspect, clean, and grease the lower shock linkage for my Honda CRF250X. The same methods will work for the Zongshen RX3.
10-13-2014, 12:53 AM | #600 |
You must mount the bike on a center stand to perform this maintenance. You can purchase either an aftermarket lift stand, or the optional, Zongshen center stand.
http://item.taobao.com/item.htm?spm=...51&ns=1#detail
Display Modes | |
