09-05-2010, 03:53 PM | #46 |
It is indeed a two stroke, and I see now that I misread your prior post. When you said "Usually you only see roller bearings in the bottom ends of 2 cycle engines", I was thinking that you meant only the big end.
Now I see that you meant both ends of the connecting rod. I believe we are now on the same page. Your description of rollers in a two stroke vs. babbit in a four stroke makes perfect sense. How else would you maintain a hydrodynamic wedge between the bearing and journal in a four stroke?
09-05-2010, 06:54 PM | #47 |
Even Kawasaki ended up going to plain bearings in the Ninjunk.
You could do the crank with a 60T jack and a loaded tractor trailer, but I would, in the interest of your fingers, not recommend it. I bought the neatest tool the other day @ Princess Auto, a ball joint press.....I *think* it would do a GY6 crank with some fooling around. |
09-05-2010, 07:49 PM | #48 |
you guys can pick press's at harbor freight for a decent price..200 bucks gets a very decent press.
Display Modes | |
