#31 | ||
The main good stuff I can't photograph, like how nice it runs not and no longer acts and smells rich. Top speed did not change, I guess it's an 85 MPH bike which is fine with me, and 15 MPH faster than I need to go on it. I just used top speed as a rough indicator of power output. I think I'm still down some because when they were new the articles had them clocked at 98, no way mine would do that. But, 33 years ago was a long time!
Happy to serve. |
#32 |
I had RTV sealed boots on my radian. Did the job.
Also you can make a video for us. ![]() 85 on a little bike like that is fast enough.
#33 |
#34 |
The KZ400 site was instrumental and helped me with my project very much. 85 is plenty fast, it was just a way to test power output. the bike felt very fine at that speed. I don't have it done. Oh the joys of antique bike repair. this AM there was puddle of gas under left carb drain, the needle valve must be defective, incorrectly installed or some dirt may be in there. Also the vacuum slide diaphrams, while intact, are old, swollen, and balky and will get replaced.
Happy to serve. |
#35 |
I have had, well, "reasonable luck" replacing the steel needle valves with viton rubber tip valves stolen out of automotive carb rebuild kits. (otherwise give the needle a rap, on the blunt end, with a gasket hammer)
#36 |
A friend is sponsored by this Canadian company. He races in the WERA series vintage bikes.
http://www.siriusconinc.com/search_r...search&x=0&y=0
#37 |
That's the kit I bought. Might be a defective valve or some crud. I'll look at it when I get home. Might be able to get by without pulling the carbs.
Happy to serve. |
#38 |
I need some advise men.
The leak is fixed, but I have a 'hanging idle'. It's from a vacuum leak at the carb boots where they mate to the head. I ID'ed this by spraying carb cleaner at the area and the hanging high idle (4000 RPM) can right down until the cleaner evaporated. New boots for this bike are not possible to find, and the replacement boots (used) are what's on there now. Any type of a sealent I can use that will stand the heat AND the exposure to fuel? This is my last issue that keeps this bike from being a daily driver! A crazy(?) idea I've had is to spray the boots with bedliner (redneck but maybe a good idea) to seal them or dip them in that plastic coating used for coating tool handles, but I don't know if that stuff will take the heat. I don't know if bedliner will flex without cracking when I put the carb bodies back into the boots. Ruberized undercoating is yet another thought. Someone help! :oops:
Happy to serve. |
#39 |
Not sure if the RTV is available in black. It worked really well for me.
I think the tool dip and bedliner would be okay with the fuel, but I don't know about the heat. Allen
#40 |
Look at what I found:
http://cgi.ebay.com/ebaymotors/Kawas...item23046a0c2d Maybe there was supposed to be a gasket there that was tossed by some prior owner?
Happy to serve. |
#41 | |
![]() ![]() Spud ![]()
#42 |
I think my yamaha had the gaskets and a suzuki gs used o-rings to make that seal.
The gasket should be easy to make. Allen
#43 |
Suggestions on what to make it from? Should I use a sealer on it? Its not a big job but enough of a PIA I'd rather just do it once more.
Happy to serve. |
#44 |
You can get gasket material at an auto parts store. RTV sealant could also be used but I would prefer the gasket as clean up would be easier if the job had to be done again later.
#45 |
Gasket material (auto parts store, though in a pinch cardboard would do (the non-corrugated kind). Lay the material over the surface on the head, and using a gasket hammer, make the gasket in about 20 seconds. High temp RTV would do it too, just allow a good dry time.
Display Modes | |
