#32 | |
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-13-2020 at 01:18 PM. |
#33 |
I have read that the Hotcam is a drop in and requires no mods to the engine. What kind of performance gains could you expect by only swapping cams and not doing the port/polish and piston swap?
#34 |
With out increasing the compression ratio and opening up the ports you will loose low end power. The higher compression makes up for that.
#35 |
Any update on how that 18 tooth front sprocket is doing? Is it hitting the case at all? I wouldn’t mind buying one if it manages to clear the cover.
2019 Venom X22R K&N pod air filter, removed cat, 105 main jet, 36 tooth rear sprocket, RK racing 428 chain, oil cooler, NGK plug, bar risers, aftermarket mirrors, Grab On grip covers, phone mount/charger, Pro Grip tank protector, Chase Harper tank, tail, and saddle bags. |
#36 | |
Honestly, even if I weren't installing a cam, or raising compression on any engine these bikes run, I would still open up the exhaust port, as well as port match and smooth out the intake a little. If you don't believe you are capable of doing your own head porting there is actually a shop in Missouri that will do pretty damn good port work for a pretty good price (Around $150-200). This is their facebook page. https://www.facebook.com/LFRPowersport/ You can see some of their porting examples. Corey Lansdown is who I talked to and he is a knowledgeable guy that does good work. Get in touch with them and see what they tell you. As far as increasing the compression goes. Given the specs of the cam in question, I would want no less than a 9.5:1 static compression ratio to avoid losing low end power. Mid range and top end would perform just fine. It might not be quite the fire breather that Jerry is making, but it will have most of the benefits of the cam while also running cooler. I am not 100% sure what the X22R CB engine has stock, but usually the OHC motors are around 9:1 compression. So, at the very least you could have the head decked 2 thousands (.002 inches, or .5mm) to bump it up to about where you would want it.
#37 |
Never installed an 18 tooth. Even though an 18 tooth might fit, it will pass too close to the case for me. If you get too much slack in the chain and it decides to jump tooth you can plan on buying a new case.
#38 |
The stock gaskets on the engines have a triple layer head gasket. Like the CRF230F guys you can separate the gasket and use one layer which will give you a .5 increase in compression ratio.
#39 |
Doh, wrong thread!
#40 |
#41 |
Update. Bike has been parked in the shed since Tuesday night. When i got home Tuesday my my fan for my AC condenser unit decided to degenerate so had to take my truck Wednesday as it would of been a pain to carry a huge fan on the back of the bike so i took the truck. Not as much fun to ride as the bike. lol Turns out the supply house had the wrong fan so had to order a new one. Good thing i have a couple of window units for back up. Now it looks like we have rain for a few days.
![]() ![]() ![]() ![]() So yeah, not so much of an update but it's all i got at the moment. ![]()
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 05-14-2020 at 11:49 AM. |
#42 |
for anybody looking to port there head, I ran across this thread this morning. Very informational and with pictures.
#43 | |
#44 | |
#45 | |
As far as the thinner material around the guide. Where it is the thinnest doesn't really need much material removed anyway. Most of the material removal is at the bowl and especially next to the guides just leaving the bowl along the roof of the port right next to the guide.
Display Modes | |
