#31 |
okay cool, i did a few more measurements of where the bolts are at, and it looks like it will fit. Hope i don't have to remove the gas tank.
2021 Boom Vader Gen 2 BD125-10 Current 2011 DRZ400S Current 2006 LIFANIZED ROKETA DB-06 200cc Sold 2008 Ninja 250R Sold 1984 Honda aero 125 Sold 1980 Honda CM400T Sold |
#32 |
You will have to remove it but its simple. What is your concern?
Happy to serve. |
#33 |
Nice score on the parts bike, Gamma!
![]() You will need to remove the exhaust header, carburetor, clutch cable, throttle cable, drive chain, fuel tank, et cetera, before you can remove the engine. ![]() ![]() ![]() ![]() Spud ![]()
#34 |
Good score on a parts bike. Engine swap is not too bad. Should take an afternoon to get it done.
#35 | ||
Im so lucky to have found that bike on craigs. Once my bike is good to go me and my bro may throw my roketa engine into the other one and use it as a fun bike. :twisted: Ill keep you guys updated.
#36 |
Happy to serve. |
#37 | |
#38 |
Cleaned up my work area, Got all my sockets and wrenches organised and back in the case...
Yeah removing the gas tank was really easy actually, One bolt, and then it slid out. Feeling real good about this. ![]() ![]() ![]() Ill start a new thread pretty soon here, once i get deeper into it, Next is to remove the carb.
#39 |
Remove the carb, exhaust, chain, and all but one or two mount bolts. leave those and the wiring attached until the last minute so you don't forget where what goes...
Pics are good for the forum and will also help you remmeber things so take many at each phase. It's like a trail of breadcrumbs to find your way back. Find help to remove and replace the engine. It weighs about 75 lbs and is a little unwieldy.
Happy to serve. |
#40 | |
As for removing the carb, how do i remove the cable that goes from the throttle to the top of the carb? should i just pull it out? Want to be certain before i do anything. Yeah ill have my bro help me with the weight of the engine. Thanks again guys ill keep the questions coming as they pop up.
#41 |
Unscrew the cap and the cable will pull out easily with the slide attached. If you need to change the slide to the one that comes on the new engine/carb removal of the cable will be self evident on inspection of the slide.
Happy to serve. |
#42 |
Okay i unscrewed the cap, and pulled it out a bit (the cap and cable), it had like a spring, and then a plastic piece at the bottom? do i take all of that stuff out? i put it back in without fully removing it, i didn't want to mess it up.
it looked similar to this one
#43 |
Just pull it out straight and gentle. Nothing will fly off.
When you replace it take not of a small locating pin in the carb bore that locates the slide in a particular configuation. This needs to be lined up when you put it back together. 8)
Happy to serve. |
#44 |
Done, you explained it perfectly
![]() everything is off and ready to go, wasnt really hard at all! ![]() Is it going to be difficult to maneuver the engine out? i think i see how it will come out, but just wondering if anyone had any problems. Thanks for the guidance, seriously! You especially fast doc, you rule man.
#45 |
One trick to making the engine easier to remove and replace is to lay something soft on the floor and lay the bike on it's side. Lift/wiggle the engine out from that position.
IIRC with these bikes it's best to lay the bike on it's left side and remove/replace the motor from the right, but YMMV. :wink:
Happy to serve. |
Display Modes | |
