09-30-2014, 11:15 AM | #421 | |
09-30-2014, 11:17 AM | #422 |
That's not the feeling I get so far. I suspect they'll measure spare parts for us, though.
09-30-2014, 11:19 AM | #423 |
His jacket matches the bike!
09-30-2014, 04:07 PM | #424 |
Yeah you're absolutely right about that. I think 13 is about as small as I would go. Damn it comes stock with a 13t, Master Spud is definately on the right track with the rear sprocket.
Mark 2015 Haosen Hawk 250 2014 CRF250L 2014 CB500X Rally Raid |
10-01-2014, 02:06 AM | #425 |
As I suspected, the NC250 engine in the Zongshen RX3 is not a copy of an existing engine. According to Minsk, this engine is an original design by an Italian company which also designs engines for Beta motorcycles.
http://forum.onliner.by/viewtopic.ph...37264&start=60
10-01-2014, 02:22 AM | #426 |
Here is a photograph which details the digital dashboard of the RX3.
The digital dashboard utilizes a Siemens microprocessor which can be set for either U.S., or metric measurements. It has a fuel gauge on the left, and an engine coolant gauge on the right. It also includes a trip odometer, clock, gear indicator, and digital speedometer. The top of the dashboard features an analog tachometer.
10-01-2014, 02:26 AM | #427 | |
10-01-2014, 02:33 AM | #428 |
I agree; the more I learn, the better I like this motorcycle. I believe Zongshen has established itself as a formidable manufacturer with the arrival of the RX3.
10-01-2014, 02:38 AM | #429 |
After the bike is delivered, I am confident we will quickly get the gearing, and the rear wheel figured out. I am also considering a 21-inch, front wheel for this bike.
10-01-2014, 03:16 AM | #430 |
The Italians created a very nice design for the Zongshen NC250 engine.
The camshaft is supported by two ball bearings. http://item.taobao.com/item.htm?spm=...71&ns=1#detail The valve lash is adjusted by screw tappets on the roller rocker arms. The tappets are easily accessible by means of two, large ports in the cylinder head cover. The spark plug is easily accessible from the right side of the bike, so you don't need to remove the fuel tank to inspect, or change the spark plug. This is a very convenient feature if you are having ignition problems during a trip.
Spud "Never argue with an idiot. He will drag you down to his level, and beat you with experience." Mark Twain 2015 Zongshen ZS250GY-3 (RX3) 2006 Zongshen ZS200GY-2 (Sierra 200) 2005 Honda XR650L 2004 Honda CRF250X 1998 Kawasaki KDX220 Mods made to my Zongshen ZS200GY-2: http://www.chinariders.net/showthread.php?t=6894 Last edited by SpudRider; 12-13-2014 at 07:27 AM. |
10-01-2014, 05:57 AM | #431 |
I found some fork and shock absorber specifications in the following thread.
http://forum.onliner.by/viewtopic.ph...7264&start=240 Fork Diameter: 37mm Fork Length: 795mm Fork Stroke: 200mm The fork diameter and fork length seem accurate to me. If the fork stroke is also accurate, fork travel is 7.9 inches, which is excellent for Chinese forks. Standard, 37mm Chinese forks have a travel of 6.5 inches. Shock Absorber: Length: 390mm Stroke: 60mm These are very nice specifications for the shock absorber. The RX3 shock has a progressive, lower shock linkage, spring preload and rebound damping. Minsk TRX 300i reviews state the bike has a very good suspension. I was very pleased to discover these specifications for the suspension; I hope they are accurate.
10-01-2014, 06:15 AM | #432 | |
I'm with you on this. I think an 18" rear nd 21" front would be perfect for those of us that may stray off the pavement. More ground clearence and a big hoop up front to roll over obstacles. I ran a 21" up front on my Tenere and it made a huge difference in the soft stuff. Should keep the bike geometry pretty close to stock as well.
10-01-2014, 08:32 AM | #433 |
We may be seeing the RX-3 sooner tha later. Copied from the CSC front page:
When the bike completes the US certification process (expected to occur within the next several weeks), we’ll call you and ask for a $500 deposit. You pay the balance when the bike is delivered.
10-01-2014, 09:38 AM | #434 |
Wolftrax - thanks for posting the update. I'm anxious to take delivery. Heck, I've even put away funds for the $500 deposit!
Spud - I may have missed this in another thread, but were you able to find oil capacity? And I wonder what weight is recommended? I understand that there are two oil pumps in this engine… one for the cylinder and to spray the piston, and the other for the transmission (so the trans won't have to rely on oil splash for lubrication.) Thanks for the great photos of the top end. It really does look like servicing this bike will be straight forward and without having to remove much (if any) tupperware. If I read correctly, the only plastic that might need to come off is on the left side to service the air filter or reach the battery, but otherwise it's almost all accessible. |
10-01-2014, 10:47 AM | #435 | |
While I'm excited about this new bike, I'd rather see a known platform copy, rather than a clean slate design.
Display Modes | |
