#331 |
Figure out which end of the hinge had the knurled end of the pin; probably the end closest to the end of the case. Put the new pin in the other way, smooth end first. It should just slide in until you get to the knurl. a couple of taps with a hemmer should seat it.
The reason for putting it in the other way is so you will have fresh material gripping the knurls.
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
#332 |
However , it fell out once for a reason. A little insurance, right?
#333 |
smooth side first worked. omg it was so tight i had to hammer it in. I can't believe the darn thing fell out, now seeing how tight the fit is. weird!
thanks guys! i didn't use any glue. |
#334 |
I'll cheat a bit here...not what I did today but what I did this past weekend. There is a rally in the mountains of Virginia, put on by the Twin Valley Riders, and I have gone for the past few years. It's a hoot, in an area of great riding, and they have fantastic food. This year I rode the Zong. It's 300 miles each way. I won't bore you with the route numbers, suffice to say I was on US or state highways all the way. Think 55-60 mph. The bike ran like a top and I enjoyed myself. Of course I had to cope with the mountains as I got out west. At times I had to gear down to 4th just to stay anywhere near a legal speed...not a big deal. At the rally site I parked in a line of BMWs. My bike has a rondel on one side (the other one fell off) so most folks walked by, did a double take, and came back to ask 'what in the hell is that?". I must have explained to 30 different people about the goodness of Zong. Most got it, some never will. Bottom line: CSC will be getting a bunch of hits on their web site!
I checked the oil temp from time to time. The dash said I had 4 bars most of the time. My IR thermometer indicated 205F so I'm close to boiling any junk out of the crankcase. I do not have any liquid in the OSC tube (That may be leaking because I can get a trace of gasoline smelly liquid when I run my finger by the tube). At any rate, the bike ran great. I will note that on the highway the engine noise gets to be a bother. I think it's intake noise rather than exhaust because the level is directly related to throttle position, not engine speed. After 300 miles I found myself to be really tired, something I'd never seen with my other (larger) bikes. On the way home I passed through Danville, Virginia. The Tank Museum is located there. It was closed on Sunday (only open on Friday and Saturday) but if you have any interest in tanks or artillery this is mecca. He has about 120 pieces on display, all in a huge warehouse. ![]() Peter Y. Last edited by pyoungbl; 09-18-2016 at 07:03 PM. Reason: spelling |
#335 |
Good day to all!
![]() So I want to install on my motorcycle heated handles for me and for the passenger. (Passenger froze less than I am, but she complained of a cold). Therefore, I have a question. Will generator withstand the extra load in the 60-70 watts? ![]() ![]() ![]() |
#336 |
Rus, you should not have any problems with 60-70 watts of extra draw. I have powered a heated liner that draws that much. Just to be careful you might want to add a volt meter to your bike. On most motorcycles the alternator does not start charging until the engine gets up to 3500 rpm. Our Zongs have to run well above that just to get away from a stop!
Peter Y. |
#337 |
CSC sells heated grips for the RX3: http://www.cscmotorcycles.com/HEATED...p/csc-1556.htm. The bike pulls something like 160 watts with normal use and with it's 'generator'/stator able to put out 300w you will be fine. Depends on what other accessories you might also have on the bike like aux lights, usb plugs, etc. You should add any of those up to get the available. Nice bit of information here on the RX3's electrical system: http://californiascooterco.com/blog/?p=15503
2017 BMW F800GS Adventure |
#338 |
Thanks for answers
#339 | |
Peace and Zong Life
#340 |
Thank you all! The manual says that the power of 200 W, but I do not believe the instructions 100%. Instructions for the Russian lying largely. So far, I will proceed from the fact that the battery is installed on a motorcycle on 12 volts and 20 ampere fuse. Those. We get the critical power of 240 watts for me.
Тhen the question: is motorcycle actually consumes 160 watts when operating in standard mode without any additional load? ![]() ![]() ![]() |
#341 |
Bash plate mods
We have a couple rainy days to justify shop time so I adjusted the valves on my trusty Zong. This was also an opportunity to modify the CSC aluminum bash plate. Taking a cue from this forum I reversed the front mounting bolts so the nuts will now be facing the front wheel and thus easier to work with. This turned out to be a super easy mod:
![]() Then I cut down the top part of the bash plate so it can be rotated enough to change the oil. ![]() ![]() |
#342 |
So the cutouts allow you to swing down the skidplate for service? Bottom two mounts just rotate in place?? Very cool
#343 |
Nope, the bottom two mounts are disconnected, the skidplate pivots down but is still connected near the exhaust valves. It would be very easy to just take the plate off completely now that the nuts are so easy to get to.
#344 | |
#345 | |
Also, I tried to do reverse the front mounting bolts, but was not successful. I put a socket underneath and hit the top of the bolt with a hammer, but they just wouldn't budge. Any tips?
Display Modes | |
