#16 |
No bike in the near future hopefully by summer. Wife is at a turning point in her job problem hopefully all will be settled soon. Then sit down and talk with all the creditors and see what I can work out. In the meantime I have my fleet of Puch mopeds to keep me busy. If your ever cold stone tapped broke post an ad for an old moped. You will soon be buried in them. At least it's something to work on. Plus they are actually worth some money once you get them running and cleaned up. Mopeds just may fund my new bike/scooter whichever I get.
Aaron |
#17 |
well i hope things work out for you, i hope to see you riding soon!
My name is Justin, my friends call me Stix. 2008 Kawasaki KLR650 Candy Lime Green ______________________________ I am the official China bike registration Guru For the State of Maryland..... HA. |
#18 |
I could be wrong, but that small, hard to get at screw at the front of the carb is the fuel/air mixture screw for idle/small throttle opening, if any throttle opening at all. If you think it is lean when you are on the throttle, lower the clip on the needle. As for the backfiring when you close the throttle, try this little experiment. Pull the choke on a small amount and see if it goes away. I have an Arctic Cat ATV that does the same thing. In my situation with the ATV, it is too lean, & is probably your case too. Adjusting the idle fuel/air mixture screw will probably help that. Adjusting that screw will probably affect your idle speed too.
#19 |
That's a good idea to use the choke to check things out. I will have to try that.
2009 XR650L Big Red Pig Tusk bar risers 2007 X-Moto(Jetmoto) GY250 --mods--- 15/40 sprockets UNI Pod Filter 2007 Shineray TMS 200XYi--Betsy ![]() Betsy Mods:______________________ Acerbis DHH headlight FMF Powercore pipe Uni Pod Filter |
#20 |
liverchip
I have that same exact bike but red so yours is doing the same thing i moved my down 1 slot but havent been able to test it so mush snow and to cold so when it clears up ill let u no if it works
Display Modes | |
