#16 |
Looks great and ready for the white stuff. BTW, where are you located? You might want to add it to your sig. It may help others.
#17 |
I’m located in Illinois, just updated it, hoping we get a good amount soon so I can put it to use already lol.
#19 |
Nice. I'm sure you found out, as I did, those chains on the rear really help out.
#20 |
Yes, they sure do! With the right set up these things can become little work horses! Feels like a complete different machine than the day I brought it home. Very impressed.
#21 |
I'm starting my 4th winter plowing with mine. It's held up great. http://www.chinariders.net/showthread.php?t=21115
#22 |
I have set mine up for plowing too. It has worked great. I use spiked chains because of gravel driveway, wouldn't use them on anything paved, but with those and the no diff rear end, it will go anywhere my larger 4 wheel drive ATV's will go in the snow.
I did have to add 70 lbs of weight in the rear end to counter balance the blade I have when its up high...and that helped with traction too. |
#23 |
It looks great. I almost went with the Rhino 250 but decided on the Pentora since it's a clone of the Yamaha Raptor. I often regard utility ATVs as "tractors", but I can see the Rhino would take very little to become a racing, mudding and jumping quad.
I outright ended up inventing a manual, semiautomatic plow for mine that is nearly finished, but I wandered into some other mods and work that couldn't be left behind. I have about 10 days before the snow comes so it's not a down to the wire situation. I will go up an inch in tire size due to what is standard on the market, then decide if I want to adjust the gears but I doubt it. I get lift in a hard shift to 3rd gear already, but more top end will break 60mph and the inch to the tires adds 5mph. |
Display Modes | |
