10-05-2018, 08:09 AM | #16 |
Tight is not the issue make sure it is not coming in contact with the motor I had mine positioned so that it would at times make contact.
2016 Brozz |
06-15-2023, 09:41 AM | #17 | |
Hey man, my hawk is making he same noise, only on wot in high revs or at max speed. When I go 50, it starts buzzing or grinding whatever, with the more I push it, the more and harder it buzzes. If I go up to 60, the bike will do fine, as I give it more the speedometer starts going down but I feel as if I'm going the same speed. I dide use synthetic to run it twice but I didn't ride on it. I've been using t4 or t6 10-40 or 15-40 ever since. It runs smooth down low. There's a slight inconsistency in the idle, but it sounds good. I was thinking it might be my speedo cable. Bit idk I'm hoping it's not too engine. Have you found out what it was? |
Tags |
bashan, bsr, engine, noise |
Display Modes | |
