07-27-2016, 08:45 AM | #17 |
Gerry shipped me a replacement slider/fastener for my rear caliper that loosened and fell off, no questions asked, and I had it in 3 days. I'm sure they will help you out.
2005 CBR600RR
2016 CSC TT250 Coming Soon |
07-27-2016, 08:50 AM | #18 |
any idea of what caused the issue? since one was tight and the other buggered up, suspect someone screwed up when they changed the front sprocket?
07-27-2016, 09:46 AM | #19 |
cheap low grade bolt. pretty uncommon for the bolt to strip its own threads instead of what it is going into. granted it was better this way but the bolt should almost always be superior material to what it is going into.
07-27-2016, 09:53 AM | #20 | |
Go to the hardware store, get a bolt and like kohburn says, run a tap into the hole and clean it out first or you'll have a repeat performance.
07-27-2016, 03:35 PM | #21 |
Well, I know that it was buggered up upon assembly or it was a malfunction of some sort. All my worries are gone. Spoke with Gerry and they have assured me all parts are covered under warranty and all will be replaced. This is why I bought from CSC. This company stands behind their products and I couldn't be happier with their service.
*2016 CSC TT250 *2006 Zongshen ZS200GY-2 *1973 Honda SL100 |
07-27-2016, 03:37 PM | #22 |
I'm just hoping it didn't strip out the hole that it went into. Which case, more parts needed and more work to be done. However I bought my bike for my family reunion in the mountains this Thursday through Sunday and I'm going to be very disappointed if it's not up and running by then. :/
07-28-2016, 08:51 AM | #23 | |
edit...the sprocket is likely much harder steel than the bolt and may not be damaged, you could try and source a bolt locally for less than a dollar and try and bolt it up? Does the other sprocket bolt thread into the hole? |
07-28-2016, 01:15 PM | #24 | |
07-28-2016, 08:55 PM | #25 |
***Update***
I cleaned out the holes in the sprocket and at first glance I thought they were stripped but the grooves were filled with metal shavings. One of them was perfectly fine and the other is 1/4 way stripped. I am waiting for the new sprocket and I'll install. Also purchased some American made bolts. 😀
07-30-2016, 02:37 AM | #26 |
I had a similar symptom with the weird pattern noise. Mine was from the right side though. Took off the right side cover and there was a shaft with a cup bolted to the end of it. The bolt was loose which allowed that cup to rub the inside of the case. Tightened it up and the noise went away. The problem was intermittent at first and progressively got worse. They aren't kidding when they say Check the torque on ALL the bolts when assembling a china bike.
Check out my Hawk 250 Motovlog Channel https://www.youtube.com/channel/UCUU...JoVrsuhnV-7Zkw |
Display Modes | |
