Old 07-12-2013, 01:56 AM   #16
midlifekrisiz   midlifekrisiz is offline
By ignition, do you mean the key switch?
that is correct
I could be wrong......it has been known to happen<div><br /></div><div>core directive 172: No member of the core shall report for duty wearing a ginger toupee</div>
Old 07-12-2013, 11:33 AM   #17
Have you removed the cover to see if either switch has broken wires? If so, they could be repaired.
Old 07-12-2013, 11:59 AM   #18
for what they cost at saga we are just going to buy a new one for the 200 and the 150 got the spare that i had here.
Old 07-12-2013, 05:29 PM   #19
hmmm ok got the filter installed but now it has no git up and go :(
Old 07-18-2013, 12:54 AM   #20
changed the main jet to a .40 and moved the needle c-clip down one from middle and now she has the get up and go it was missing.
now there is a squeak in the rear that sounds like brakes are stuck on ....but their not
Old 07-18-2013, 01:34 AM   #21
I do have the 130 slow jet as well ....i have it idling (to a degree). anyone think i should put the 130 slow jet in as well?
Old 07-18-2013, 10:00 AM   #22
wow i must have been tired when i wrote that ...... have changed the main to a 130 and have not changed the slow yet
Old 07-18-2013, 10:35 AM   #23
What were the original jet sizes?
Old 07-18-2013, 10:47 AM   #24
unfortunatly there are no markings on the original jets.
I went on the advice of another forum that said that when you change to a uni filter to bump the jets in the stock carb up to a main .40 and a slow 130 (if needed)
Old 07-18-2013, 11:06 AM   #25
You must still be tired.
I presume you mean a 130 main and a 40 slow. I'll check my spare carb and see what the jets are as a baseline. Those sizes sound a little large to me.
Old 07-18-2013, 11:12 AM   #26
yes you are correct
Old 07-18-2013, 11:55 AM   #27
ya this is how i wanted to spend my 4 weeks off.....fixing the wifes atv
Old 07-18-2013, 12:04 PM   #28
I just checked, and the stock slow jet is 34 and the main jet is 103. It's feeding 150cc, and the only change you've made is a pod filter. I'd try a 110 main and the 34 slow jet. If it won't idle, try the 40.
Old 07-18-2013, 12:16 PM   #29
do you know if saga carries jets?
I have to go there today to get parts for my friends beast.
Old 07-18-2013, 12:58 PM   #30
i have officially lost my sense of humor
Search this Thread:
Advanced Search
Display Modes
