#196 |
Awesome. May pull the trigger today.
Brian Previously owned / operated MOTO Xtreme selling American Lifan / Check out my friends at www.armattanquads.com "Imagination is more important that knowledge" Albert Einstein |
#197 |
Looks good.
Is there a copper gasket between the pipe and the motor? The only thing I will miss is the chrome cover over the muffler. I think it is a nice cosmetic feature of the Brozz
2016 Brozz |
#198 |
There's what I THINK is a lead gasket? I reused it with no problems. I like the look of the aftermarket silencer, but I may try to retrofit the stock catalyst cover, but I don't know how it'll look being chrome over the heated stainless. I might try mocking it up for pics tonight.
![]() Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf...... |
#199 |
If your talking about retrofitting the cat on the new exhaust you just installed, I'm 99% sure its not a real cat, just hollow.
Also, I think you and I are the only ones still running the stock carb. I'm one jet size up now, and I'm pretty sure I need to go up another. Let me know with this new exhaust system what jet you end up sticking with.
#200 |
I think he means trying to fit the stock exhaust heat shield/leg guard on the aftermarket pipe. Wouldn't be too hard to do, just a couple of tabs welded on with a nut on the back side.
#201 |
Wrap works too. I just didn't want the bare pipe too close to Mrs. 2LZ leg.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 05-26-2020 at 12:24 PM. |
#202 |
Looks like you used a high temp silicon spray on that wrap. Or is it just black header wrap? Hard to tell.
#203 | |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 This is the stuff I used to spray it with. I can't remember from where though. I think I had Auto Zone order it and I picked it up. https://www.pricefalls.com/product/d...d=192583471181
#204 |
This is what I like to use, and what I ordered for my exhaust. Not supposed to use the Silicone spray on the Titanium wrap series, and the LR Wrap edges are part of the weave so fraying edges is not really an issue like most fiberglass wraps. It's also installed dry, no wetting, and once it is heat cycled a couple of times the titanium turns hard and essentially locks into place. This also makes it pretty much unable to be removed without it breaking apart, so this makes getting that wrap right, and tight, the first time important.
Note - I ordered a bit longer (33ft) than necessary because I like to do a 50% overlap when I wrap exhausts. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#205 | |
*yup. You're 100% right* ![]() I'll keep you posted bud. I need to do a plug chop and see how this 110 main is treating the porcelain
#206 | |
2016 Brozz |
#207 |
You found the correct ones, Goat? Post a link for the rest of us man! Lol
#208 |
Not the 1/2-5/8" I remembered, but still decent. This pic was taken from the left side, fingers touching. I'd guess maybe 3/8-7/16" clearance.
#209 |
Wrap looks good.... Are you getting the results you wanted?
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#210 | |
When I get them I will post my results, I also ordered this https://www.aliexpress.com/item-img/...00017.4.HHiJs8
2016 Brozz |
Display Modes | |
